  • 1994 - 1995 Specific Tech
Electrical nightmare, HELP!!!
  • Thread starter Thread starter officer dick
  • Start date Start date Mar 8, 2008
officer dick
26
NC
Mar 8, 2008
  • Mar 8, 2008
I just completed a 1000 mile trip to my duty station, no problems. The engine lite came on periodically like before, I believe it to be the o2 sensor, no big deal right. A week later though, I get this electrical problem that will come and go as it pleases. Any time I accelerate sharply, hit a bump or decelerate quickly my battery light flashes as my volt gauge jumps around and my temp gauge follows suit. Now today I also started getting a burnt clutch/electrical fire smell at random. I seemed to be isolated to the cabin, so I pulled out the $10 Wal Mart special radio and it stopped. Untill I got out of the car and I smelled it again. I figure clutch, but with the POS radio I've got in there, well, I don't know. Any other time I've smelled a burnt clutch it's been smoking and smelling allot more potent. Are these problems related? Does anyone have some insight as to what it may be?
D
Danman765432
471
Nutley, NJ
Mar 9, 2008
  • Mar 9, 2008
Maybe it could be something with your alternator power wire?
Bosko5.0
1,067
longwood, FL
Mar 9, 2008
  • Mar 9, 2008
Pull the radio out and look around in their for burnt wires. Check fuses make sure the right amp fuse is in the right spot. Also check your battery cables and terminals.
If I were you I would unhook the battery when not in use so your car doen't decide to burst into flames.
desertcox05
379
south atlanta
Mar 10, 2008
  • Mar 10, 2008
when my electric fan quit working i smelled that same thing in the cabin. i'm not saying that IS your prob. only another place to look.
thanks for you service to our country
officer dick
26
NC
Mar 10, 2008
  • Mar 10, 2008
Well, I'm an ass. Turns out my left rear park brake is stuck. I'm going to fix it today.
Still doesn't solve the problem of the flashing battery light though. I've jiggled the hell out of all the wires I could find while someone watched the gauges to no avail.
HISSIN50
34
129
Mar 10, 2008
  • Mar 10, 2008
What wires were jiggled?
A loose charge cable (as noted) will make the reading bounce around. Carefully wiggle test the cable and connections. The PDC connection is notorious for corroding.
The fusible links for the alt are near the driver's side of the PS pump. Ensure they have not started to burn.
Check the alt fuse in the underhood fusebox. Remove it, check the terminals and reinstall it. It can lead to issues if it's resistive.
A partially grounded switch circuit can cause the light to flicker artificially. However, since the voltmeter also goes wacky, that might rule that out (said another way, the light illuminates because there's indeed an issue).
I might also lightly tap the regulator while the car idles. Have an assistant see if the reading goes wonky.
Good luck.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
K
Electrical charging issue
  • knucklehead11
  • Jul 15, 2024
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 16, 2024
Mcmahst
