electrical problem
TorontoJohn
51
Simple question...
When my car idles the headlights and gauge lights are x-bright. When you give it gas they are XXX-bright. What could cause this. I am using the stock volt meter gauge, and when I am idling it is rather low, but when I am cruising it's in the middle of it's reading. Sounds like a bad alt?
Even without U/D's, with a stockish idle and a 2G, it can be normal. As 86BC pointed out, the U/D's exacerbate the problem.
Not sure how UD pullies are going to cause excessively bright lights at idle and above. UD pullies usually cause dim lights. If I'm reading it right he's saying his lights are extra bright at idle and going super bright at higher rpms.
It sounds to me like it's a bad regulator or internal alternator component failure causing excessive voltage output. You need to get a meter (stock gauges aren't good enough for troubleshooting) and check for a possible overcharging problem.
To err on the side of caution I wouldn't be driving until you verify this to be the problem or not. The problem could get much worse.
I think the X's were a scale of sorts (he used a scale of X through XXX, where X is the dimmest and XXX is the brightest [or an issue for another website]). :D
He could have used a scale of 1-3 instead, where X=1 and XXX=3, and 3 is brighter than one.
i would say that unless you go get a better alt you are going to have this problem. that being said i do have a better alt and i have the same problem with my car at a idle. mind you my car idles at 600 rpm maybe if i bumped that a little i wouldn't have such a issue.
That would make sense.
Unexplained variables just don't work when trying to troubleshoot.:shrug:
I hear ya - adjectives would have been easier to understand. Maybe he thought more people would read if he put XXX and headlights in the post. :D
