  • SN95 4.6L Mustang Tech
Electrical Problems
  • Thread starter Thread starter Turbo Saleen
  • Start date Start date Apr 27, 2004
T
Turbo Saleen
15
  • Apr 27, 2004
Hey guys, I had my battery relocated to my trunk. Lately I've been having probs with it starting. So I bought a battery and it still did the same ****. Barely turned the car over. Is the starter taking a dump? The battery is grounded to the body in the trunk, should I ground it someplace else? I've been push starting the car ever since. Where and what should I check first?
Thanks guys.
damacman
529
Phoenix, AZ
Apr 28, 2004
  • Apr 28, 2004
You should absolutely ground the battery someplace else. Run the ground wire through one of the drain plugs in the trunk and connect it solidly to the uni-body frame. Grind the paint off the spot you choose. This should help solve your problem.
T
Turbo Saleen
15
  • Apr 28, 2004
Thanks, I will try it this weekend. It's grounded to where the spare tire is right now. Thanks
Carl
613
Johnson City, TN
Apr 28, 2004
  • Apr 28, 2004
Definitaly find a new ground, and be very careful that your are not overheating your wiring now. If your are introducing alot of resistance into the wiring, heat is the end result.
T
Turbo Saleen
15
  • Apr 29, 2004
Ok after a lil more research. I found out that when I turn the key all the way it turns over and stops, but when I only turn it half way it turns over and starts. Any ideas?
T
Turbo Saleen
15
  • May 6, 2004
anymore ideas? Is there any testers I can get to help me out?
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
