Resolved Electrical
  • Thread starter Thread starter The special Medic
  • Start date Start date Jul 6, 2024
  • Tags Tags
    electeical
T
The special Medic
10
Oklahoma
Jul 6, 2024
  • Jul 6, 2024
I have a 1998 mustang V6 and the either the eec fuse or the fuel pump fuse blows after like 30 seconds ( the fuse was misslabled on some modules so idk which)
Admin Dude
Jan 4, 1985
43,529
21,695
234
Box behind Walmart
Jul 6, 2024
  • Jul 6, 2024
The special Medic said:
I have a 1998 mustang V6 and my alternator case is positive,
I don't know what this means.
it is misfiring on one of the cylinder banks,
This sounds like a separate issue.
and it keeps blowing the fuel pump fuse
This also sounds like a separate issue.
Have you pulled codes?
Something like this will get you there: https://www.amazon.com/ZM201-Profes...nced-Vehicles/dp/B0C2V3RYLY/ref=sr_1_9?sr=8-9
T
The special Medic
10
Oklahoma
Jul 6, 2024
  • Jul 6, 2024
When the ground cable was hooked up to the casing of the alternator it acted like it caused a short, and at the moment there is not a check engine light
Admin Dude
Jan 4, 1985
43,529
21,695
234
Box behind Walmart
Jul 6, 2024
  • Jul 6, 2024
You still need to pull codes. The trouble light doesn't illuminate for all codes.
Do you have the means to remove the alternator and have it tested at a nearby auto-parts store?
On a parallel note: What kind of shape is the battery in?
Admin Dude
Jan 4, 1985
43,529
21,695
234
Box behind Walmart
Jul 6, 2024
  • Jul 6, 2024
I'll leave this here too. I'm certain we have one for this section but I can't find it>
How To Read Ford Check Engine Light Without a Code Reader – BackYardMechanic
www.backyardmechanic.org
T
The special Medic
10
Oklahoma
Jul 7, 2024
  • Jul 7, 2024
I should be able to, and the battery is recently new and in good shay
Mcmahst
5 Year Member
Jan 19, 2021
706
284
83
Laguna Woods CA, fort Mohave AZ
Jul 7, 2024
  • Jul 7, 2024
I know my Autozone lets you borrow an ODB-1 tester, maybe try that?
T
The special Medic
10
Oklahoma
Oct 14, 2024
  • Oct 14, 2024
I have a V6 1998 mustang and my fuel pump fuse keeps blowing where do I start?
T
The special Medic
10
Oklahoma
Oct 14, 2024
  • Oct 14, 2024
Ok so atm the only thing it's doing is blowing the fuel pump fuse (1998 so the fuse may be mislabeled)
89ripper
925
309
103
Rockford, Illinois
Oct 14, 2024
#10
  • Oct 14, 2024
  • #10
Sounds like you have a short somewhere. Do you have access to some wiring diagrams? You are gonna need to do some digging
T
The special Medic
10
Oklahoma
Oct 14, 2024
#11
  • Oct 14, 2024
  • #11
I found some diagrams and apparently the fuel pump fuse and the eec fuse were mislabeled so I'm gonna start by checking the O2 sensors
89ripper
925
309
103
Rockford, Illinois
Oct 14, 2024
#12
  • Oct 14, 2024
  • #12
So you are saying you were blowing the eec fuse?
4gwenddolau9
14
Flagstaff
Oct 15, 2024
#13
  • Oct 15, 2024
  • #13
Hi, does the fuse blow instantly when you turn the key on? Does the fuse last for a while? a few starts, a few days, a week or more? Do you live where rodents are an issue under the hood, eating wiring and such? Is the fuse socket in the box corroded? Was the first fuse that blew, corroded? Do you have an electrical meter? Have you run out of gas in the last 6 mos. to a year? Do you know how old the pump is? I know that's a lot of questions but you can start at the connector to the pump at the back of the car look for power & ground, if the fuse will hold long enough. I know there are others on the forum with better answers than mine but I thought I'd give it a go here.
LILCBRA
Mod Dude
Dec 6, 2005
6,587
5,599
194
Corn County USA
Oct 15, 2024
#14
  • Oct 15, 2024
  • #14
@The special Medic - I've merged your 2 threads since they were both the same basic topic and both had the same title.
T
The special Medic
10
Oklahoma
Oct 16, 2024
#15
  • Oct 16, 2024
  • #15
It pops after about 30 seconds
Fuel pump is new
T
The special Medic
10
Oklahoma
Oct 16, 2024
#16
  • Oct 16, 2024
  • #16
I think, it's one of the 2 because I've seen some say it was mislabeled but it's marked as the fuel pump fuse in the manual so idk
4gwenddolau9
14
Flagstaff
Oct 31, 2024
#17
  • Oct 31, 2024
  • #17
Hey, sorry I did not see your reply. Did you get it fixed?
T
The special Medic
10
Oklahoma
Nov 25, 2024
#18
  • Nov 25, 2024
  • #18
No I haven't had the chance to look at it till now
T
The special Medic
10
Oklahoma
Feb 3, 2025
#19
  • Feb 3, 2025
  • #19
Thanks for the help, as of Thanksgiving week I was able to solve the issue, a wire running to the coil pack was frayed and was shorting to the hood
Reactions: 89ripper and Mcmahst
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
