Check the inertia switch to make sure it hasn't tripped.
Look for 12 volts on both sides of the inertia switch. If it is on the red side, but not the red/black, the switch has tripped. No power on the red side means the ECC relay is bad.
Look for 12 volts on the yellow wire that feeds the fuel pump relay. No power here and the fuse link has blown.
Look for 12 volts at the yellow wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring or connections.
Turn on the key and jumper the fuel pump test connector to ground as previously described. Look for 12 volts at the Light Pink/Black wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed or there is a broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the Red wire and Red/Black wire. Power on the Red wire and not on the Red/Black wire means the inertia switch is open.
The Tan/Lt Green wire provides a ground path for the relay power. With the test connector jumpered to ground, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the Tan/Lt Green wire. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
If and only if you have followed the test procedure to this point and still haven’t found the problem, the computer is suspect.
OK I HAVE POWER TO THE RELAY WHEN I JUMP IT THE PUMP PUMPS IS IT POSSIBLE THE RELAY I BOUGHT IS DEFECTIVE INERTIA SWITCH HAS POWER TO RED AND RED BLACK DOESNT THE RELAY SEEM TO BE THE PROBLEM THANK YOU MRBREEZE58
Power to both the red & red/black wires means the inertia swich is good.
All testing is done with the ignition switch in the run position. Do the tests in the sequence given and don't skip any steps.
There are 3 possibllities:
1.) Relay is bad or wrong part number. Ground the tan/lt green wire on the relay. If the relay is working, it will make the pump run.
2.) Broken tan/lt green from the relay to the computer. Turn the key off prior to disconnecting the computer wiring connector.
Remove the passenger side kick panel and remove the the computer wiring connector. Turn the key back to Run to perform the test.
Locate the tan/lt green wire and jumper it to ground. A safety pin or paper clip may be needed to make contact with the metal pin in the computer connector. If the relay does not energize and make the pump run, the tan/lt green wire is bad or has a bad connection.
3.) If you got this far, the computer is bad. You have grounded the tan/lt green wire at the computer and made the pump run. That means the computer isn't supplying ground for the relay circuit, and has failed.
