  • 2005 - 2009 Specific Tech
Electricity problem
  • Thread starter Thread starter erad
  • Start date Start date May 24, 2009
E
erad
  • May 24, 2009
Does mustang GT 2005 has a problem with their alternators? Because once my car get warm I loose power and the electricity voltage drops and my coils gets burned! Could be anything else apart from this that the car is loosing electricity?
ski
380
May 25, 2009
  • May 25, 2009
Did you have the battery and alternator checked?
chad9350
248
Lake Charles, LA
May 25, 2009
  • May 25, 2009
These cars are WAY sensitive... do you have a running light out, maybe a blinker?
Did you just go over a bumpy road, the clips on cpu in front 'jiggle' loose rather easily.
Oh, tap on fuse box, our 2005 are famous for this....
E
erad
  • May 25, 2009
I have chacked the alternator and the battery. they told me it could be the problem from you car computer because until now i have changed my coils for 5 times. once i put new sets of coils and sparkplugs the car runs fine for 1000 Kms. After that the car starts cuting on a high RPM onces the engine becomes hot! many of my friends said its not an meachical issue its the problem with your electricity.... i am going to change the car computer and re-tune the car hoping that the issue wll be solved.
chad9350
248
Lake Charles, LA
May 25, 2009
  • May 25, 2009
disconnect, and reconnect 3 plugs on cpu
E
erad
  • May 27, 2009
done that, but the car is not starting...
Sanctus
146
Trabuco Canyon
May 28, 2009
  • May 28, 2009
My car's in the shop for the same thing. Car wont start, not enough voltage...
They don't know what the problem is. (Go figure)
Sanctus
146
Trabuco Canyon
May 28, 2009
  • May 28, 2009
Just got off the phone with the Ford stealership. Apparently it was a blown 30m Fuse and a faulty PCM relay. Took them 5 hours to figure it out after I told them I thought it was a blown fuse... Apparently you don't have to be too quick with the mind to be a service tech.
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
1970 Mach 1 voltage regulator
  • 70ivygreen
  • Oct 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 27, 2026
Mcmahst
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
