Eletrical Problem (Help a noob out) THx!
USAstang
24
Hello all,
Haven't posted in a while here, and when I have, you guys are life savers.
I recenetly installed a new 3G alternator in my 1991 mustang. Everything was working fine for a few days (went from 12.8-9v w/ the old 2G, to 13.8-14.1v w/ the new 3G). I was extremely happy with the difference, car ran good, noticible difference wipers reacted quicker, turning signals faster etc.
Now on to my problem, lately the 20-AMP inline fuse that is attached to the battery side of the starter selonoid keeps blowing out. Hence my fuel pump wont engauge to start the car. I made a quick test of a direct connecet with a peice of aluminum foil just to see if the car was able to crank and run, and she ran beautifuly.
Just the inline fuse blows randomly. :shrug:
I really don't know where to start attacking this problem. Is this inline fuse critical or is it even supposed to be there? I even attempted to run a 35amp fuse and it melted it as well.
Any ideas are GREATLY appreciated, so I can create a game plan so when TurkeyDay vacation comes I can tackle this issue and resolve it.
Thanks again Mustang gurus.
Are you talking about a fusable link, or an actual fuse?
If you pull the fuse out, and do a resistance (ohms) check on the accessory side of the fuse connection to ground how much resistance do you get? Meaning, connect one probe to ground, the other where the fuse goes in -not- on the battery side.
You either have a bad pump drawing too many amps, or you have a short somewhere.
First you want to test ohms from the wire to ground, and then with a wiring diagram, start at the fuel pump and work your way upstream to that wire and start disconnecting that circuit one a time and look for the ohms to change. If you can get it to change, you know the short is after the connect you just disconnected. If there is a change after unplugging the fuel pump but nowhere else, than your problem is most likely the pump, although there could be a short between the wire and the first connection, so check that too.
There are no fuses under the hood of the car, so this is someone's repair job.
What color wire does the fuse connect to? What else doesn't run when the fuse is removed?
The wire color is a clue as what circuits are involved. One of the circuits fed by a yellow wire supports 3 or 4 other circuits. That one pulls much more than 20 amps.
Wiring diagrams for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
Note that the 91 wire code colors are different from the 87-90 model Mustangs.
I see, when I get home I'll let you guys know more info.
As to what runs or doesn't run... the only thing that doesn't enguage appears to be the fuel pump.
Thanks for the input so far from everyone's part.
