  • 2005 - 2009 Specific Tech
eletrical problems
  • Thread starter Thread starter jimleejones
  • Start date Start date Nov 26, 2010
J
jimleejones
  • Nov 26, 2010
These are the problems that I am having. (DTE FLI DATA ERR) and my system check said all my fluids are low (oil pressure low, brake fluid level low, Fuel level low) that my parking brake is engaged (when it is clearly not) and my TCS is off. Nothing shows up on my information center like my turn signals (they still work but no clicking or flashing green arrows) I checked my oil, it seems to be fine. The car seems drivable, but I don't want my brakes giving out, you know. I was thinking maybe I blew a fuse for the sensor which controls all that stuff, but I couldn't find a fuse which controlled any of those things in the manual. The night lights on the stereo stay on. I think that causes a battery drain. I recently purchsed a new battery and the above problems stopped, but now the same probs are happening again. Any help would be appreciated.
ski
380
Nov 27, 2010
  • Nov 27, 2010
Check the battery voltage for at least 12.7 V with the engine off, and 14-14.5 V with the engine running.
If the 1st one is low, then recharge the battery with a trickle charger.
If the 2nd one is low, then the alternator may be bad. However, that normally triggers a CEL.
If both are ok, then check the carpet in the passenger's footwell for wetness or dampness. If you feel any, then the Smart Junction Box(SJB) probably got wet from a water leak resulting in the electrical problems. The normal fix is to replace the SJB.
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
