Eliminating Power Steering
SadbutTrue
2,391
Thousand Oaks, California
I want to chuck my power steering unit... it leaks, it robs power, it looks bad in the engine bay, and the steering feeling is sloppy. I'm okay with building some arm muscles for parking lot driving if need be. What's involved? Do I just take the thing off? Will I need a new steering box? Anything else?
You don't need to change the steering box or the inner/outer tie rods. Everything else has to be changed out.
Drag link
Pitman Arm
Idler Arm
Remove all the PS stuff
This may not solve your sloppy steering problem as the sloppy steering could be caused by any number of things. Your tie rods could be worn out, your box could be going bad and your idler arm could be done as well. If its just the slop in the steering you are worried about I'd look into making sure your ball joints are all still good and maybe replace the inner/outer tierods first and see if that helps.
How is the rest of your suspension ? The other parts of your suspension will play a key roll in how your car responds to steering input.
