emisons by bypass
  • Thread starter Thread starter kmplace
  • Start date Start date Oct 25, 2010
K
kmplace
9
wapakoneta
Oct 25, 2010
  • Oct 25, 2010
can anyone help me on how to bypass all the emisons such as egr and air pump solenoids so my check engine light will go off.the car never goes into closed loop because of this
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Oct 25, 2010
  • Oct 25, 2010
Need more details.
If anything, this is a good reason NOT to rip out all the emissions stuff. You gain 0 hp in addition to all the headaches of a car that just won't run right.
What did you remove? And did you run the check engine codes to see what the car doesn't like?
87AODGT
373
Toms River, NJ
Oct 25, 2010
  • Oct 25, 2010
well if you want to turn all the emissions off you need to get something like a tweecer or moates quarterhorse
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 25, 2010
  • Oct 25, 2010
If you remove the egr, you need a plug and delete plate from here RJM Injection Tech » EGR Eliminators No tuner needed.
The solenoids on the fender you can just remove that along with the smog pump but don't forget to plug the vacuum lines and H pipe port. You will get codes 44 & 94 but they won't effect driveability or closed loop.
HISSIN50
34
129
Oct 25, 2010
  • Oct 25, 2010
I would not remove anything until you know what's really wrong with the car and have a better understanding of the emissions equipment.
G
GofastJD
11
  • Oct 25, 2010
no smog pump
I have the same issue, I bought the car and the smog pump was bypassed.
wouldn't the one less pulley drag help a little for efficiency and the cooler air, I've always thought it would help for at least a few hp.
so I can pretty much trash all the other emissions garbage right>?
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Oct 25, 2010
  • Oct 25, 2010
See that's the thing. Everyone thinks ditching it gains hp. You gain maybe 1/2 hp on the smog pump. Everything else doesn't rob power and ditching the egr can make fuel economy worse.
A common theme on the boards is " help, i deleted my emissions stuff and now my car runs poorly"
K
kmplace
9
wapakoneta
Oct 25, 2010
  • Oct 25, 2010
well i agree you shouldnt just go ripping emissions out. but as many people have ran into it was like this when i purchased the car.. i know for a fact the car never goes into closed loop and there maybe other problems.the car is 92 lx 5 speed..i had and 88gt with a maf conversion with the same setup as this car only difrence was the 92 has a a9l and the 88 had a x32..the 88 ran good so im trying to figure out my situation over the winter
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 26, 2010
  • Oct 26, 2010
Fix what's broke for now...Find out what the computer says is wrong.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
