Engine bay wiring help needed
  • Thread starter Thread starter stang_380
  • Start date Start date Oct 14, 2009
stang_380
76
St. Paul
Oct 14, 2009
  • Oct 14, 2009
Well ive decided to relocate my engine harness and wiring behind the dash board and i have a few questions. I no longer have cruise control so do i need to keep the connectors pluged into the speed control amplifier? I know that the VSS sends a signal there but if i toss the amplifier will my ECU still recieve the proper signal from the VSS? Next question my A/C and smog is all gone so with the A/C gone do i still need the WOT relay? From my understanding this relay is to signal the a/c fan clutch to dissengage when at WOT. Is that its only purpose? Ok and one last question. For a couple years now ive been using a wire to jump from the ignition to the red/green wire that allows the fuel pump to prime and ignition to go hot. Well with the dash currently out i was able to locate the bad fuse link in the red/green wire. Its says its a 20 gauge wire. What is the best way to repair this? Can i use a maxi fuse? What kind of amperage does this wire pull?
Please help.
Erik
D
doorvip
22
  • Oct 14, 2009
you can buy a roll of fuse link wire, 20 gauge is gray. I got it at napa. my same link went in my car, fuel pump and ign. I just used butt conectors to install and cut out the burnt one.
stang_380
76
St. Paul
Oct 15, 2009
  • Oct 15, 2009
Thanks for the reply.
Does anyone know if i can eliminate the thermister air diverter and bypass solenoids with out affecting performance? these are the solenoids on the passenger fender apron. I will still keep the egr plumbed and hooked up.
Thanks
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
