engine block supplier
  • Thread starter Thread starter firemansam
  • Start date Start date May 27, 2010
firemansam
113
Mississippi/Iraq
May 27, 2010
  • May 27, 2010
I have been looking into the engine build for my car lately and have talked to a reputable engine shop and they said that for the 427 stroker kit to be dependably floggable my best bet would be to go aftermarket block. since he is the builder i want to use and he made very good points i have been lookin at the avaliable blocks. I knew there were aluminum blocks avaliable out there based on the specs of a Windsor engine so i looked into it out of curiostity. I am now thinking that would be a cool way to go (read: i am young and dumb with too much money haha ) but have come across a delima, being the good shopper my mom always said i should be i began searching for more than just Dart as a supplier, and found Man O' War Blocks, they appear to be quality blocks with extra reinforcements and such in thier designs. Now comes my question, which would you say, in your opinion is the better buy? the MOW block is about 500 or so cheaper... or even more if i opt for the un finished block and have it bored and blueprinted on my on... ideas? this will be a purchase a little while down the road i am just tryin to get my plans straight for now. thanks for helpin!
brianj5600
1,964
Middle TN
May 27, 2010
  • May 27, 2010
How much power are you trying to make?
Wicked65
490
NORCAL
May 27, 2010
  • May 27, 2010
adperformance.com short blocks already built for you, with your block of choice for a fairly resonable price in my opinion.
Bennet racing engines is also another excellent choice.
but if your not planing on going over 450-500 hp, you really have no need for a dart block, unless you really want one. Remember too, when you buy after market block, the machine bill will still be 500 to 1000 more. They are usually very rough from the factory.
9
96 DOHC Cobra
542
Cerritos, CA
May 27, 2010
  • May 27, 2010
I thought Dart and Man O' War were the same company. Aren't they just separate lines produced by World Products?
brianj5600
1,964
Middle TN
May 27, 2010
  • May 27, 2010
351w blocks are good for more than 500hp. I have only heard of 2 breaking and both were over 800fwhp according to weight/trap speed. I would not worry about the block below 700hp. I plan on testing mine to 800 or so.
firemansam
113
Mississippi/Iraq
May 28, 2010
  • May 28, 2010
brianj5600~ i am shooting for somewhere above 550 naturally aspirated (ditched my supercharger idea), but its not the power that the builder is having an issue building in that block, its the rotational mass of the 427 stroke set up... he refuses to build anything over a 408 on a stock block.
Wicked65~ thanks for those suppliers, but i have my builder set and he and i prefer to start with a bare block and let him handle it all, less chances for a miscue... also these blocks can be bought from the manufactures prepped, meaning all machine work done and cam bearings installed as well as freeze plugs and such where all you have have to do is start the build with install of your internals...
96 DOHC Cobra~ as far as i know they are seperate intites, if some one knows for sure other wise let me know!
So is the gain in the handling of the 100 and some odd pounds worth the 4 extra grand for the aluminum block or should i save the cash and go with an cast iron design?
brianj5600
1,964
Middle TN
May 28, 2010
  • May 28, 2010
$4000 is a lot to me for 100 lbs. If I was racing heads up or wheel to wheel it would be worth it. If I was just going to drive it around and occassionally get on a track, I doubt I would spend $4000. It also depends on how much $4000 is to you. Some people carry more than that in their pocket. I would probably build a big bore motor if I had an aftermarket block in the 440+ range.
firemansam
113
Mississippi/Iraq
May 29, 2010
  • May 29, 2010
brianj5600~ i agree it is alot, and although right now 4k is about 2 weeks of work this job is finite so only gonna have that for about 4 more months... thanks for all yalls help! i think i will stick with iron haha unless someone has an aluminum one just layin around they wanna give me or sell me cheap! haha
blown65
1,938
Queen Creek Arizona
May 29, 2010
  • May 29, 2010
X2, lots of guys run 700-800 hp on the older 9.5" blocks. I would think 800 would be pushing it. At 600 and under I wouldn't even worry about it. Spend it elsewhere. Your engine builder is thinking the 302 and 351 blocks are the same strength. Friend of mine has a 427 stroker with quite a few runs down the strip over the 4 yrs its been together. No issues.
blown65
1,938
Queen Creek Arizona
May 29, 2010
#10
  • May 29, 2010
  • #10
Big bore with some good hiports or victor heads.
brianj5600
1,964
Middle TN
May 29, 2010
#11
  • May 29, 2010
  • #11
Some heads with 8 valve cover bolts would look nice and make some power.
I see you update your sig. So close. You will get it.
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
