I am slowly putting together the motor pictured below. I just finished installing in the pistons and was reviewing my “how to rebuild your small block ford” book and noticed the compression and secondary ring gaps are suppose to be positioned near the piston pin about 30-45 degrees apart (yellow arrows). Although, I put gaps 180 degrees apart perpendicular to the piston ring (e.g. the areas where the most cylinder ware occurs) (red arrows). This is a Heche en Mexico 302 block stroked 3.4 @ 0.060 over (352 cubic inches). Since the block is nearing the end of its life and it will be a Sunday driver only…should I care? Is it worth the effort to pull all the pistons and correct this?
<IMG src="http://home.pacbell.net/lorax1/352motor042.jpg">
If the image does not show up view it here (newbie to picture attachments):
http://home.pacbell.net/lorax1/352motor041.jpg
