All,
I need help diagnosing my newly aquired 91' coupe. I got a decent "deal" on it and it looks good, but is not running right. I planned on building a engine when I bought it, but I just want to get it on the road for a while till I get the money.
What it is (as reported by previous owner who knew little, intentionaly or otherwise):
91' Coupe, 5-speed, 306ci, cold air kit, 70mm throtlebody, has an aftermarket cam of some kind, EGR blocked with a plate, emissions pump removed, stock headers, H-pipe
Problem:
NO POWER. It falls on its face completely when any more than 1/3 throttle and even WOT. If you hold the throttle in, it is like you turned the key off, but will ocassionaly backfire. It will idle well with a nice little lope and can drive around fine if you baby it < 3500rpm.
Things that I have done with no helpful change whatsoever:
1) checked timing and plug wire order.
2) checked fuel pressure. 39psi, and 39+ some when driving and trying to accelerate.
3) checked TPS ~.9 - 4.9ish volts
4) swapped a known good Mass Air Sensor
5) swapped for a known good ECU
6) replaced coil and coil wire
7) swapped for known good distributor - damn oil shaft fell down in pan - replaced
8) took it to a garage and had the codes read
34,84 - EGR sensor (probably because it was blocked)
29 - speed sensor
67 - neutral safety switch
41 - fuel at lean limit
9) replaced speed sensor, got new gear and fixed speedo.
In light of the code 41, I believe it might leaning out like the ECU isnt seeing the Throttle Posision sensor, maybe in the harness somewhere, cause signal is coming out of the TPS sensor.
My Dad (old school, pre EFI) thinks the guy put the wrong cam in there (old firing order). He maybe right after all.
Things I plan to check next unless I get guidance.
TPS signal to the ECU, Injectors, valve timing????
HELP - Thanks in advance
KJ
Problem:
29 - speed sensor
HELP
KJ
