  • SN95 4.6L Mustang Tech
Engine Dying?
  • Thread starter Thread starter ACSPONY
  • Start date Start date May 1, 2005
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
May 1, 2005
  • May 1, 2005
This morning, I pulled into a parking lot to get something out of the glovebox, put the car into park, and it died. The engine cut off. So I started it up again and it turned over no problems so I drove off. Did it again at the store but started up fine. From then on it was ok, no stalling and everytime I put it in park it stayed on as it should. I did the "fog light mod" last night and disconnected the negative battery cable. Did I not tighten it enough?
~A.C.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 1, 2005
  • May 1, 2005
Why don't you check the negative terminal? Anyway, it is probably your IAC. Replace it...
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
May 1, 2005
  • May 1, 2005
Doesn't the IAC control the engine idle? The car idles fine, rpms stay consistent and I've never had any problems before?
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
May 1, 2005
  • May 1, 2005
ttt. anything besides the IAC? why would it crap out now? I don't want this thing to sh1t on me while I'm driving lol.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 1, 2005
  • May 1, 2005
Well, maybe it dying that one time was just an anomaly? Perhaps it is fine...
ToplessStang
591
Montreal, Canada
May 1, 2005
  • May 1, 2005
Disconnecting the battery cleared the PCM's KAM. When it is reconnected the computer has to relearn all it's parameters. It is rare but when first reconnected, the car may stall as the PCM relearns the idle speed parameter. If it doesn't happen again, your ok. IF it does well then you can start looking at maybe IAC valve problem or something else for that matter.
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
May 1, 2005
  • May 1, 2005
Thanks Topless and Kilgore for the replies , it hasn't happened since this morning so I'm crossing my fingers I'm good to go.
~A.C.
starchman
73
Sheridan, AR
May 1, 2005
  • May 1, 2005
When your IAC valve goes bad (at least when mine did) it begins as a VERY intermittent problem; however, once the engine has reached its operating temperature, the IAC won't cause the engine to die. Again, this is what mine did; I had to give it throttle until it warmed up, then it ran fine. If I stopped for a few minutes and restarted, it started up without a hitch.
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
