I just got this 95 GT 5.0 and it has a miss. I cannot rev it past 3500 without it popping and not wanting to rev any higher. The motor shakes and it will act like its gonna stall and then catch itself and do that repeadly until it eventually stalls. The motor has 112k on it. We checked compression on all cylinders its right around 125psi on each of them with no oil on the plugs. Checked firing order it was good, replaced the distrubuter with a known good one and it was the same. Replaced the injectors with good ones that didn't do it and all the injectors were pulsating No CEL. I pulled all the wires off the cap and they all got spark. New plugs/wires. Does anyone have any idea what this could be? I'm about to pull the valve covers but I don't want to unless I've run out of ideas. Could the issue be a bad rocker or bent pushrod? Wouldn't that cause bad compression on a certain cylinder?
Dan
Dan
