  • SN95 4.6L Mustang Tech
Engine knock
  • Thread starter Thread starter CrazyHorn
  • Start date Start date Jul 27, 2005
1 of 2 Next Last
C
CrazyHorn
184
Gatineau
Jul 27, 2005
  • Jul 27, 2005
Well when I am inside the car I can hear a little knock from the engine, two days ago it was a little worst than what I normally hear, I think I have seen a tsb for engine knocking on the 02 gt but anyways I am just thinking is this normal for a 4.6l and if not what can fix it, is the tsb actually working ?
sgarlic
3,085
Jul 28, 2005
  • Jul 28, 2005
Could you give a little more info. about your motor? Any mods not listed, and how many miles? Did the knock develop suddenly or has it always knocked a little bit (you say when you're inside, but has it always done that?)
Also.. what weight oil do you run?
trinity_gt
3,125
81
99
Canada
Jul 28, 2005
  • Jul 28, 2005
Like sgarlic said, more info needed. When does it do this? All the time? Only when cold? Hot too? Under heavy load or light load? Both? Is it a heavy knock or a light rapping?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 28, 2005
  • Jul 28, 2005
More info is defintely required. However, if it IS detonation, then better gas may help...
C
CrazyHorn
184
Gatineau
Jul 28, 2005
  • Jul 28, 2005
Well there is no mod on the motor except a k&n air filter and a magnapack, anyways mods are in the sig btw But the knock is not loud or anything, its just a little knock, and it happens sometimes, it doesn't matter what wheater it is, hot or cold, its just a little weird, I use synthetic oil only, mobile and whatever whats the dealer suggest for it, I do my oil changes every 6000kms(around 4500miles) anyways you guys think I should go with higher octane, or maybe just a tune, I dunno, the car didn't lost power or anything doh.
Is it normal for the 4.6L v8 to knock, do they almost all do it, and is the tsb working for it, I've send it to the dealer and thats what they told me that its normal to have a knock on the 4.6 and the tsb didn't work so I'm just wondering if they are saying is true.
Give Me TP
936
Republic of Texas
Jul 28, 2005
  • Jul 28, 2005
It's not normal
C
CrazyHorn
184
Gatineau
Jul 28, 2005
  • Jul 28, 2005
Ok, the car is still under warranty, I'm just wondering whats the fix on it and if anybody had the same problem ? Thanks
RedDaemon
3,470
9
108
Atlanta, GA
Jul 28, 2005
  • Jul 28, 2005
why dont u try picking up urself some Mystery Oil?
C
CrazyHorn
184
Gatineau
Jul 28, 2005
  • Jul 28, 2005
W
WillDuhhBeast
339
Jacksonville Florida
Jul 28, 2005
#10
  • Jul 28, 2005
  • #10
I sometimes think I have a knock.. but I'm assuming that if I think I have one, I probably don't. When I have the windows all rolled up and no A/c or radio, i can sometimes hear a ticking noise thats very faint. It seems to be there sometimes, and others it seems to be gone. I run premium because I feel safe that way, though this still occurs. I ran some seafoam and it didn't change much in the way of the noise.
Maybe you can relate to this.. or maybe its jsut in my head
C
CrazyHorn
184
Gatineau
Jul 28, 2005
#11
  • Jul 28, 2005
  • #11
Well is about the same for me, but now it seems like I heard it a little more than before, I heard it when the windows are down, anyways its not really a problem yet but I just dont want it to become worst.
Btw what engine oil do you guys recommend, I use mobile 1 syn, the last one was made by ford with there own brand of synthetic, also like to know whats a good filter to go with it, thanks again.
D
Disturbed One
191
#12
  • Jul 28, 2005
  • #12
Does it do it just sitting there at idle? WOT? normal driving? Where at does the tick sound like it's coming from?
C
CrazyHorn
184
Gatineau
Jul 28, 2005
#13
  • Jul 28, 2005
  • #13
Seems like its coming from the engine, when I press on the gas at idle you can here the knocking going a little quicker, when I drive the car I cant hear it because of the wind and magnapacks, I can only hear it at idle, its not very loud.
Q's Stang
317
Indianapolis
Jul 28, 2005
#14
  • Jul 28, 2005
  • #14
when my engine was knocking it wasnt real loud but noticable whenever & whereever i drove...my car didnt seem to lose too much whenever i drove i was thinking it was just a tick, but after a few weeks my car started acting funny w/ my dash lights & also died on me a few times...if i were you & didnt know much about engines id take it to a performance shop & let professionals look at it...or if you know anybody who is good w/ cars have them give you some advice
C
CrazyHorn
184
Gatineau
Jul 28, 2005
#15
  • Jul 28, 2005
  • #15
Well its at the dealership right now, I'll probably pick the car tomorow, anyways do you guy have the TSB # for the mustang ticking problem, if there is any, I guess I should just go at another dealer.
Q's Stang
317
Indianapolis
Jul 28, 2005
#16
  • Jul 28, 2005
  • #16
dealerships blow to me...i took my car there b/c i had a squeek in my right rear tire and they said it was b/c of my rotors & rust build up and shaved the ends of both my rear rotors...awesome work ford!
turns out my right rear axle was warped...go figure
V
vipergt
47
#17
  • Jul 28, 2005
  • #17
I believe your OK my 04 with only 5000 miles has this flutter at 3/4 throttle or at least at wot the exhaust and engine is so loud I cant hear. Its done it from day one and I think it the air flow going through the intake, but I could be wrong.Mine does not sound metallic, but like a sheet flopping in the wind. As long as you got power and no smoke or fire then your
Q's Stang
317
Indianapolis
Jul 28, 2005
#18
  • Jul 28, 2005
  • #18
i guess im more of the its better safe than sorry...
i dont want to be that guy saying oh your engine is knocking...but the more you leave something wrong...the worse & worse itll get
RedDaemon
3,470
9
108
Atlanta, GA
Jul 28, 2005
#19
  • Jul 28, 2005
  • #19
_StangGT__ said:
http://www.autobarn.net/chmm013.html
C
CrazyHorn
184
Gatineau
Jul 28, 2005
#20
  • Jul 28, 2005
  • #20
After how many miles do you usually use the mystery oil, also why the hell do they call it mystery oil ?
1 of 2 Next Last
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
