  • SN95 4.6L Mustang Tech
Engine Light On
  • Thread starter Thread starter JMstang7
  • Start date Start date Jul 11, 2009
1 of 2 Next Last
JMstang7
29
Baltimore
Jul 11, 2009
  • Jul 11, 2009
My engine light is on but I have MIL eliminators. They are installed right. I ran my diablo tune and said it was running lean. I have a O/R X pipe. But i thought the MIL eliminators would take care of that problem. Any suggestions. Thanks.
jeremy canter
402
Orange County , NY
Jul 11, 2009
  • Jul 11, 2009
A lean condition has nothing to do with your rear o2's > which is what your mil eliminators should be hooked to >your rear o2's only tell you when you cats aren't working right .
your car running lean might be it learning the new exhaust or a lose air pump feed line or a intake gasket leak > just erase it and see if it comes back.
squeak93
2,348
417
164
Joplin, Missouri
Jul 13, 2009
  • Jul 13, 2009
If your running lean, you have a few possibilities.
A: you have a vac leak allowing unmetered air into the engine
B: you have an exhaust leak BEFORE the front o2's.
C: Your tune is off.
D: You have a bad front o2
Do you have any codes?
JMstang7
29
Baltimore
Jul 13, 2009
  • Jul 13, 2009
The codes were
P0605
P1211
P1690
The diablo said it was running lean.
squeak93
2,348
417
164
Joplin, Missouri
Jul 14, 2009
  • Jul 14, 2009
P0605
DIAGNOSTIC TROUBLE CODE (DTC) - P0605 ENGINE CONTROL MODULE NMVY WRITE ERROR
SUMMARY OF THE STEPS TO BE TAKEN
You need to plug your computer into an actual scan tool that can check it (if the diablo can't do it)
P1211 Injector Control Pressure Sensor Above / Below Desired
Check your sensor on the rail. Odds are its bad.
P1690 Wastegate Solenoid Circuit Malfunction
I have no idea..... I can't find good info and have no clue where to point you.
JMstang7
29
Baltimore
Jul 14, 2009
  • Jul 14, 2009
Thanks I"ll check it out
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 14, 2009
  • Jul 14, 2009
not a bad problem to have. now go fix your wastegate!!!
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 14, 2009
  • Jul 14, 2009
Ok first thing you need to do is tell us what year your car is..
I grabbed the PC/ED for a 2001 mustang since I have no info to go on and two of the codes are not listed
The PC/ED is the diag manual we use at the dealers so it's the most accurate code descriptions
the only code that I could find without knowing even basic info on your car is the p0605 that is a pcm ROM error.. improper programming or a bad PCM can cause this.
But we need more info to help and you might need a real scan tool
M
Mstg05
103
Delaware county, pa
Jul 14, 2009
  • Jul 14, 2009
None of those codes your listed are lean codes. I would go get the car scanned and find out what the actual codes are, make sure that the codes you pulled are the same codes that a scanner will pull. The newer 4.6s are not known to have intake gasket problems, but anything is possible. I would have to agree with the above post, that if you actually have a lean code, you either have a vacuum leak, or an exhaust leak, before the upstream o2. I just pulled a code on my car with the IDS, had a p0133, Ho2s11 switching slow, pulled up the pid for that and Ho2s12, turns out I have a lazy o2.
Mike97gt
it doe snot
10,633
Jul 14, 2009
#10
  • Jul 14, 2009
  • #10
yeah a bad o2 will rarely cause a lean condition since it is unlikely both front 02's will go at the same time.
A lazy 02 is your problem.
A true lean condition p0171,p0174 is most likely a vacuum leak
hotcobra03
poteet,tx
Jul 15, 2009
#11
  • Jul 15, 2009
  • #11
code help
im like the others..lost on codes..are you sure you checked them right?
605 is all i came across..
P0605 - PCM Read Only Memory (ROM) error
The PCM ROM has been corrupted
. An attempt was made to change the calibration
Module programming error
Physically damaged PCM
Reprogram or update calibration
Reprogram VID block (use as built data)
Check for other DTC's or drive symptoms for further action
code pintest,,says see note #10
Note 10: Be sure to check for aftermarket performance products before replacing PCM. For Electronic Throttle Control vehicles, P0606 may be set with other DTCS indicating a specific failure in that system, and repairing those DTCS will fix the P0606. (Follow Section 4 direction for DTCS) For diagnosing P0606 alone, an internal fault in the PCM is indicated, and the PCM should replaced. For replacement, refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) .
squeak93
2,348
417
164
Joplin, Missouri
Jul 15, 2009
#12
  • Jul 15, 2009
  • #12
Pretty much my point. The code doesn't fit the car or symptoms..... So yea.
+1 on taking it in for actual diagnostics... If its REALLY throwing those codes then your puter is crazy.
JMstang7
29
Baltimore
Jul 15, 2009
#13
  • Jul 15, 2009
  • #13
Thanks for the help. I have a 2004 Mustang GT. I am getting an actual code scanner tomorrow to make sure the codes are right. I have no idea why the diablo pulled up a wastegate code
hotcobra03
poteet,tx
Jul 15, 2009
#14
  • Jul 15, 2009
  • #14
codes
the person who owns the predator,does he have a cobra/lightning
ive used mine on other than cobra and had problems getting codes
or maybe predator was for other makes? what are gm codes?i havent looked yet
JMstang7
29
Baltimore
Jul 15, 2009
#15
  • Jul 15, 2009
  • #15
I bought the predator brand new and the codes didn't show up till I installed the O/R X pipe.
hotcobra03
poteet,tx
Jul 15, 2009
#16
  • Jul 15, 2009
  • #16
codes
what model did you buy?
mine is
5703 predator
u7142
yours should give the proper codes,,,did you clear them? and have you tryed again
hate to see you spend more money for nothing
JMstang7
29
Baltimore
Jul 15, 2009
#17
  • Jul 15, 2009
  • #17
I have the U7146
hotcobra03
poteet,tx
Jul 15, 2009
#18
  • Jul 15, 2009
  • #18
codes
well the number is right..u7146....
have you tryed again,, i tryed to switch numbers on codes po1112 comes up,,1211
i also use fords service manual for codes and test,,,605 was the only one found
hotcobra03
poteet,tx
Jul 15, 2009
#19
  • Jul 15, 2009
  • #19
my car isnt here now..
but when you open predator it tells that some codes are normall for tuned vechiles...is 1690 listed? i remember looking and didnt see it in fords codes
JMstang7
29
Baltimore
Jul 15, 2009
#20
  • Jul 15, 2009
  • #20
Yeah for tuned cars it says P0602 P1211 P1690 P0605 are normal. The only code the tuner says my car has now is a P1000
1 of 2 Next Last
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
1970 Mach 1 voltage regulator
  • 70ivygreen
  • Oct 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 27, 2026
Mcmahst
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
