Engine making ticking nosie.
OK here's the deal. Ever since I first got my car drivable there has been a ticking noise coming from the right/rear side of the engine. The noise is present whenever the engine is running but is louder when under load. Also the noise increases in frequency with engine RPM.
I've checked the usual suspects like the rockers and exhaust. I re-torqued all the rockers to 25ftlbs. I Checked the header gaskets and they (fel-pro) look fine, all bolts are tight.
Please help me before I slap some Boss 302 stickers on this thing. :(
It sounds like an exhaust leak to me, did you check where it connects to the collector? Best way to pinpoint it is to get a short piece of hose and put on to your ear and use the other to explore where the tic is the loudest, thats how i always find where noises are coming from.
Thanks for the reply Slim. I used a "piece of hose / long screwdriver" and I've localized the sound to #4 cylinder.
So if it is the exhaust which gasket do you guys suggest? I've heard Earl (Holley) makes the best. I guess if I must pay $40.00 to stop this leak I'll do it, because it sounds like a Toyota pickup.
well, if you have found the problem, the method I was going to suggest is useless, but as far as gaskets go, I have actually had the best luck with a plain 'ol Fel-pro exhaust manifold set :scratch: I know it sounds crazy, but the Mr. Gasket copper seals leaked and the fel-pro's have held up for over a year
I know you say you have retorqued your rocker arms, but have you actually verified that your valve lash is reasonable? Depending on what kind of rocker arm mounting system you have installed, simply retorquing them may or may not fix your problem. You may have a collapsed lifter; spin your engine over until each lifter is on the cam basecircle (one cylinder at a time obviously) and try and spin the pushrod by hand. If you find one that spins easily, you can bet there is something amiss.
OK it seems to be coming from the back of the block. I can hear it better under the car, but it may just be resonating through the headers.
I hooked a timing light up and the noise is the same frequency as the light flash, so its not crankshaft related.
I'm going to try some of that engine oil cleaner stuff, just to see if the noise changes any
Anyone think this might be the problem?
Yup it's down to the last of the steel core of the gasket.
I'm going to pick some new gaskets up tomorrow, which brand should I get?
I'm using Fel-pros right now and I want to use something better. I don't like the thin part on the outside. :notnice:
