  • 1994 - 1995 Specific Tech
Engine misfiring?
  • Thread starter Thread starter fgtmustang95
  • Start date Start date Apr 15, 2006
fgtmustang95
45
El Paso, Tx
Apr 15, 2006
  • Apr 15, 2006
I just replaced my spark plug wires with some FRPP 9mm and replaced the cap and rotor as well. I started the car and its got this akward shake and just a couple of moments after running I begin to hear what sounds like knocking coming from the cylinders. I checked to make sure all the boots were in properly and made sure the coil wire was also making good contact. I made sure everything was on right several times and still nothing. I also made sure each plug had its corresponding wire and correct position on the distributor. Do I have to readjust the timing? It sounds like its misfiring. Right now the timing is set at 12 degrees and had no problems with it prior to the wire upgrade. BTW the old ones were 8mm if that helps. Has this happened to anyone before? Thanks fellas
fgtmustang95
45
El Paso, Tx
Apr 15, 2006
  • Apr 15, 2006
.......Okay. Everybody just pretend that this thread never happened. :Zip2:
N
nos90gt
70
Central FL
Apr 15, 2006
  • Apr 15, 2006
Did you get it fixed?
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
Apr 15, 2006
  • Apr 15, 2006
Got the wires mixed up did we?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Apr 15, 2006
  • Apr 15, 2006
Happens to everybody......................we just don't post about it
HISSIN50
34
129
Apr 16, 2006
  • Apr 16, 2006
Dont feel bad - like Danny said, we've all been there.
fgtmustang95
45
El Paso, Tx
Apr 16, 2006
  • Apr 16, 2006
Crossed 5 and 6 on the distributor Why they put those two so close together?, Ill never know. Anyway, the code I was getting about the oxygen sensors is gone so that fixed that. My stang is running like a champ now and I can finally enjoy my gears. But no one will ever know cuz this thread never existed.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Apr 16, 2006
  • Apr 16, 2006
Quick make this a sticky lol
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
Apr 18, 2006
  • Apr 18, 2006
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
