  • Special Production
Roush Engine on the E car
  • Thread starter Thread starter ExtremeSaleen
  • Start date Start date Mar 26, 2006
ExtremeSaleen
234
Orange County, CA
Mar 26, 2006
  • Mar 26, 2006
I've torn my car down, had the block checked out and rehoned, and the heads rebuilt. There was no damage to the pistons, rings, etc., nothing visible anyway. So I had the heads rebuilt in case it was a weak spring or something allowing oil to get into the cylinder and causing the pinging, oil loss etc. I was going to put it back together this weekend but Summit sent me main bearing for the 4v.
Anyway, I've learned a few things about the build on the motor I though I'd share. Saleen rebuilt the motor using a Cobra forged crank, Manley h-beam rods, and Arias forged pistons. The heads are standard ford heads that Saleen rebuilt with new springs, valves, and cams of their own specs.
I'm reusing everything but the Arias pistons. I researched replacing the rings as there was no damage to the pistons, but they are almost impossible to get. It was a three week lead time from Saleen and expensive. Saleen didn't even want to tell me who made the pistons so I could go somewhere else, but a very knowledgeable former employee filled me in. But even from Arias it was difficult. The pistons were extremely noisy anyway so I'm going with Mahle pistons and dropping the compression just a little to handle more boost.
I am also installing a cobra pump/tank, billet fuel rails, 180 degree thermostat, new centerforce steel flywheel (dumping the aluminum), centerforce dual-friction clutch, BBK adjustable clutch cable, JBA headers, oil pressure and water temp gauge, and going back to a fluidyne radiator.
Hopefully I'll have it together in two weeks, but I'm going to miss the Knott's show this year.
marcus95
2,133
California
Mar 26, 2006
  • Mar 26, 2006
Mike,
Don't worry about Knott's. Just spend the time to get her back together perfect. We will be waiting to hear about the good news when she is back up and running.
2000xp8
SN Certified Technician
Aug 8, 2003
8,061
1,646
194
NJ
Mar 26, 2006
  • Mar 26, 2006
I probably would of used a set of worked cnc heads. You are already balls deep in this thing, might as well go for broke.
ExtremeSaleen
234
Orange County, CA
Mar 26, 2006
  • Mar 26, 2006
If I spent any more money on this project my wife would have me balls deep in a vise. But I know what you mean. The suspension is the next project but maybe I'll revisit the heads after that.
sstrayer
375
Carlsbad - San Diego, California
Mar 28, 2006
  • Mar 28, 2006
Wow, looks like you've been busy Mike, that's some interesting info. Good luck with getting it all back together.
washMO66
1,000
Washington, MO
Mar 28, 2006
  • Mar 28, 2006
You sticking with the stock blower or going to something aftermarket?
How much boost?
perauto
67
  • Mar 28, 2006
What happened to the motor just detonation and oil use? Is that what caused you to pull it down? The E motors sound horrible when cold and only a little better when warm. We have had several but not long enough to have any problems. Just curious.
Thanks Mark
gonen20
195
  • Mar 28, 2006
Mike, How many miles do you have on that Extreme of yours??? That sucks about the Knotts show, I've been in your shoes before, where the cars not together and the show still goes on with out me! How Dare they do that! Anyways, hope you still show up and say hi to all of us!!
ExtremeSaleen
234
Orange County, CA
Mar 29, 2006
  • Mar 29, 2006
Wow, so many questions.
Mark, yes the car was pinging horribly. I had it tuned three times by Steve at Powertrain Dynamics and each time it he had to shut it down on the first pull because of it. Recently it was bad enough that I could hear it and I'm deaf from six years of dejaying. The car was also losing oil, about a quart every two to three weeks. During the last oil change there was metal in the oil. It would also smoke under heavy acceleration. None of that is good. After dealing with it for almost a year, enough was enough. But after opening up the motor, there was no visible damage, no obvious place that the metal could have come from. The engine was very clean. Even with all the pinging, the pistons had held up well.
Wash, I'm sticking with the series V. I'm running about 10lbs of boost right now. I might drop to a 3.5" and about 12lbs of boost, but that depends on how it looks when I have it tuned after the rebuild. The 91 pump gas here is one of the biggest problems. I'm just looking for 425 to 450hp at the wheels safely right now.
Todd, the car has 35k on it now. I'm not selling it so I'll be honest and say I drive the hell out of it. Rebuilding the motor is maybe the price I pay for having a little bit too much fun.
98 Saleen Cobra
340
Campbell, Ca
Mar 29, 2006
#10
  • Mar 29, 2006
  • #10
Good to know that you drive the hell out of it.. let us know how it turns out.. but why not a kenne bell 2.2 blower??
ExtremeSaleen
234
Orange County, CA
Mar 29, 2006
#11
  • Mar 29, 2006
  • #11
I can think of 5,000 reasons....
Head Paneer
1,823
Surf City, CA
Mar 30, 2006
#12
  • Mar 30, 2006
  • #12
And let’s not forget the wife factor.
Sounds like you have a solid plan. I wish you much luck.
What fuel rails are you going to use?
Will you be coming to Knott’s as a spectator?
gonen20
195
#13
  • Mar 30, 2006
  • #13
98 Saleen Cobra said:
Good to know that you drive the hell out of itQUOTE]
If anyone would have seen Mike drive his Saleen at the Saleen Driving Event last year before the Saleen Facility Car Show they would have had a smile on their face and have been proud!! I watched him drive the course a few times, not knowing who he was at that time! He won an award from Saleen for running the course the fastest beating the other drivers out! So, yes I would say that judging by how he drove that day he's not afraid to drive the hell out of his Saleen! Aren't these cars made for that anyways??? Us California guys, we need to head up and hit Willow Springs Race Track, that would be fun with our cars! Last time I ran that track I was putting some fun laps in my 86 Saleen!!
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 5 6 7
3K
Classic Mustang Specific Tech Yesterday at 3:56 PM
horse sence
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Opinions on a possible project car w/ pics
  • Teen'93stang5.0
  • Mar 29, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Mar 30, 2026
Teen'93stang5.0
