  • SN95 4.6L Mustang Tech
engine "Popping"????
  • Thread starter Thread starter 98WhiteGT
  • Start date Start date Nov 6, 2004
9
98WhiteGT
Plano, Texas
Nov 6, 2004
  • Nov 6, 2004
ok, i just had a new engine installed in my 98GT. it's supposed to be from a 2001GT so i'm just going to assume it is. I just got it back yesterday and it's making a "popping" noise. From what i've read it sounds as if the spark plugs are wet or something like that. So if they are, then how do i dry them, and how easy is it??? or can i just let them dry themself out???? and if it's not that, then does anyone know what it might be????? thank you for your help!!!
edit--oh, and if it is the spark plugs, will it hurt the engine to drive it like this???
CanadaStang
2,093
Mb
Nov 6, 2004
  • Nov 6, 2004
I think you should take it back to whoever installed the motor. But if you want, pull the sparkplug boots off [one at a time] and look down the hole to see if there is any antifreeze down there. If there is, suck it out with a shop vac. Also they may have mixed up the plug wires, it wouldnt hurt to check if they are on right.
Edit:Oh, I wouldnt drive it like that.
twogts4us
4,188
12
79
Dunedin, FL
Nov 6, 2004
  • Nov 6, 2004
If it's an 01, it doesn't have plug wires...COPS.
Regardless, take it back.
CanadaStang
2,093
Mb
Nov 6, 2004
  • Nov 6, 2004
Correct, but in order to swap motors they would switch over the coil packs as well as the fuel rails from the non pi engine, otherwise to use the COPS system the entire wiring harness and EEC processor would have to be swapped out from the donner car.
CanadaStang
2,093
Mb
Nov 7, 2004
  • Nov 7, 2004
Call whoever did the swap, tell them what it's doing and that you are afraid to drive it. If they want you to drive it back to the shop and something happens, they won't be able to point any fingers at you. I doubt if it would harm the engine to drive it back to the shop, but it's better to be safe than sorry.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
