  • SN95 4.6L Mustang Tech
Engine problems please help!!
  • Thread starter Thread starter Yournamehear119
  • Start date Start date Feb 25, 2006
Y
Yournamehear119
9
  • Feb 25, 2006
Last night driving my '99 cobra, i took off in first and brought it up to about 6700 rpm pretty drawn out. When i slowed down right away the engine hesitated, seemed to miss, and ran extremly rough. After goosing the throttle for about 20 seconds It stopped wanting to die and just idled horribly. I gave it gas and took it about a block or two to the local gas station, and the whole time it misfired quite a bit. When i stopped, it ran a little better but still much rougher than usual. I popped the hood to reveal a knocking/ticking sound. I originally thought it was a rocker or lifter, than realized it was coming from around the crank pulley area, not the heads area. I shut off the car and turned it back on and it still did it. Than i revved the engine to about 3500 to 4000 rpm and when it settled, the ticking/knocking stopped, the engine shook a tiny bit and than it miracously idled like normal. I've beat on the car before and it's never done that. After that i drove around all night with no problem at all. The only thing i can think of is if oil stopped circulating well under such a load or that the traction control system (which was on) messed with the timing or something. I'm really not sure and i just recently bought the car. Please try and help because i just bought this car and I hope it's not a serious problem. i've put about 500 miles on the car and numerous hole-shots without the least bit of problem. As far as i can tell this cobra is in superb mechanical condition, but that whole ordeal just got me thinkin. Please tell me if im just making a big deal out of a fluke.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 25, 2006
  • Feb 25, 2006
How many miles on the car and what mods does it have?
cobra1923
68
Baltimore
Feb 25, 2006
  • Feb 25, 2006
Doesn't the '99 have variable intake runner length controls that get gummed up?
Y
Yournamehear119
9
  • Feb 25, 2006
hmm
the car has 60,000 miles and has an intake, throttle body, underdrives, and exhaust. Im not sure about the runners i didnt hear that do you have any more information? just to be safe im gonna go change the oil, it looked ok but its 5w20 which mite be a lil thick for a chicago winter.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Feb 25, 2006
  • Feb 25, 2006
has it had the "FIX" done to it
03GTconv
49
Fort Worth
Feb 25, 2006
  • Feb 25, 2006
Man u better hope u put your pulleys on right!! I F___ED up my 00 Gt cause of the underdrives. It did the same thing and in the end i ended up givin up my GT cause of the damage. U cant just bolt on underdrives bro theres a technique. I found out the hard way.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 25, 2006
  • Feb 25, 2006
How long ago were the pullys installed and who did it?
Y
Yournamehear119
9
  • Feb 25, 2006
The Pulleys have been on there since i bought it, and i know the guy before me didnt do it so at leasttt a yeae. should i go to a shop and have them removed and reinstalled for safe measure? cuz it almost sounded like it was coming from the lower pulleys...
Y
Yournamehear119
9
  • Feb 25, 2006
ha and what is the fix?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 25, 2006
#10
  • Feb 25, 2006
  • #10
Well, I am not convinced it is for sure the pully install but here is more info:
14520
4.6L 4V Pulley Instructions
Some 1996-2001 Mustang owners, for engine performance purposes, are adding a special front drive pulley kit to reduce front accessory drive speeds. When removing and replacing the crank pulley, if the large bolt used to hold the crank pulley undertorqued, the keyway will shear and cause major engine damage. The resulting engine damage is not warrantable. If the crankshaft pulley bolt is removed it should be replaced as it is a torque to yield bolt. The installation of the crankshaft pulley requires that a specific torque operation be adhered to. The crankshaft pulley bolt must be installed using these 4 steps: 1) Torque to 75 lbs/ft 2) Back out one turn 3) torque to 45 lb?ft 4) continue to tighten and additional 90 degrees.
03GTconv
49
Fort Worth
Feb 25, 2006
#11
  • Feb 25, 2006
  • #11
I would man, take it and have it checked out. Im tellin ya those underdrives will mess ya up if not properly installed. The "FiX" is related to the 99 cobras. At launch they unfortunatly didnt meet up to the 320 BHP that they were rated at. So ford recalled them and had them fixed to the right Horsepower rating.
Y
Yournamehear119
9
#12
  • Feb 25, 2006
  • #12
lol i'm on my way to ford now....
Y
Yournamehear119
9
#13
  • Feb 25, 2006
  • #13
oh ya and it did i called 1800fordsvt to make sure before i bought the car
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 25, 2006
#14
  • Feb 25, 2006
  • #14
When you are at the dealership, whatever you do do not utter the phrase;
"some guys on the internet told me that it could be _________"
Y
Yournamehear119
9
#15
  • Feb 25, 2006
  • #15
haha ill remember that.i think i mite get my diff fluid changed at the same time
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Feb 25, 2006
#16
  • Feb 25, 2006
  • #16
Always a good thing, pretty easy to do yourself but smelly and messy to change diff fluid.
PonyboyIsaac
79
#17
  • Feb 25, 2006
  • #17
umm all i can say is what the heck is up with people reving there engines so much, thats not good on these engines so expect problems if u rev the crap out of em.
never rev above 6100 on a stock modular(unless its an 03,04 cobra) is my rule.
R
RedGTvert
3,129
Wellington, FL
Feb 27, 2006
#18
  • Feb 27, 2006
  • #18
Huh? A Cobra is built to run that many r's, and I regularly run my 92,000 mile 96 Cobra to high 6's all the time and it still keeps going and going and going.
the98stang
2,408
Clovis, CA
Feb 27, 2006
#19
  • Feb 27, 2006
  • #19
I'd get a compression test done and make sure she's holding enough pressure..
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 27, 2006
#20
  • Feb 27, 2006
  • #20
ok if i wa you i would have that underdrive crank pulley looked at.
some underdrive pulleys when they come loose will cause this exact problem. whats causing the idling rough and misfires when the pulley comes apart, the crank sensor NEEDS to see the crank pos. correctly or you will have misfires or even a no start.
i had a friends gt do this. he found his crank pulley fell apart and was loose.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
squeak93
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
