Engine engine removal
  • Thread starter Thread starter rockyracoon
  • Start date Start date Mar 11, 2019
R
rockyracoon
874
27
49
margate NJ
Mar 11, 2019
  • Mar 11, 2019
Am replacing hci
But after removing heads i have decided to pull motor. My question is will it be ok to use headbolt holes in block to pull motor and trans.just dont want to warp the head to block mating surface.
STEVE PATTON
I smell a conspiracy
Jan 6, 2019
201
89
53
ohio
Mar 11, 2019
  • Mar 11, 2019
you'll be fine
R
rockyracoon
874
27
49
margate NJ
Mar 11, 2019
  • Mar 11, 2019
Thanks buddy
R
rockyracoon
874
27
49
margate NJ
Mar 11, 2019
  • Mar 11, 2019
Anyone else care to chime in I just dont want to reinstall the heads just to pull the motor. I will be using a leveler so there is 4 points of lifting. When I pulled motors from 4.6 stangs I allways used used intake manifold bolt boles. Never had a problem.
RaggedGT
Mod Dude
Jul 20, 2014
4,769
3,227
203
Taylorsville ky
Mar 11, 2019
  • Mar 11, 2019
+1 for you will be Fine
R
rockyracoon
874
27
49
margate NJ
Mar 11, 2019
  • Mar 11, 2019
Thanks raggedGT
sibhus
9
burke
Mar 14, 2019
  • Mar 14, 2019
Just pulled mine out two weeks ago using the advice on here using driver side head to passenger side head as mounting points with my load leveler. I was able to raise it straight up (had the tranny off), and raised hood all the way back. I checked the heads and they had absolutely no warpage or signs of stress from supporting the weight. Make sure you use at least a 2 ton picker as the last position (ie boom arm extended out) usually supports 500-700lbs.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
R
Help finding where this ground goes on the L head
  • RubberDuckUsb
  • Sep 11, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 11, 2026
RubberDuckUsb
R
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
