engine revs up
  • Thread starter Thread starter mstngcbra42
  • Start date Start date Jun 28, 2005
M
mstngcbra42
  • Jun 28, 2005
I got and idle problem with my stang. When i start it up the car idles just fine. After about 5 minutes of driving engine revs up to about 1500 rpm then to 2000 rpm. I turn the car off and turn it back on and the idle goes back to normal. I cleaned the air bypass valve with carb cleaner, but it hasnt made a difference. O2 sensors are new along with fuel regulator. Any suggestions??
DW5.0L
172
Florida
Jun 28, 2005
  • Jun 28, 2005
Check the accelerator cable linkage directly underneath EGR spacer. I have the same problem. I noticed that I am missing the clip ( ford part #9D726) that holds the other cable( ford part #9A825) in place. My engine never raced prior to losing that clip.
Any other ideas?
dstanggt50
1,316
Woodinville, WA
Jun 28, 2005
  • Jun 28, 2005
When it idles high, unplug the tps, is the idle comes down with it unplugged, try adjusting or replacing tps. (Thats what happened to my 87 gt, same issues.
M
mstngcbra42
  • Jun 28, 2005
I will try that, but also about 3 weeks back i had a short which i took care of, but when i pulled the codes and i got a 40 and a 12. I know the read that the 12 is for idle speed solenoid. Thats the reason why i cleaned the IAB. Also on deceleration the engine hesitates. When i throttle up it feels fine.
BrutalStang
261
PA
Jun 28, 2005
  • Jun 28, 2005
if it hesitates on deceleration then its probably the accelerator cable linkage.
M
mstngcbra42
  • Jun 29, 2005
I unplugged the TPS and it started to Idle fine, but i got a check engine Light. So it is the TPS. How is the tps adjusted??
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
