Engine Running Poorly
EH819
242
My car is running really poorly. I started the car earlier and it started meagerly. Then the idle was rough and it seemed like it wanted to die. There seems to be a slight ticking coming from the engine. I just ran it around the block and it was bucking and continued to run poorly. I've checked under the hood and everything seems connected. The car was running fine 2 days ago (the last time I drove it). Could it be bad gas? I did just fill up on Friday, but I did a lot of driving on Friday and Sat and it was fine. What do you guys think is wrong? Thanks for any help
Spray the IAC out with carb cleaner and check the torque on all your plugs. Then reset the PCM and hopefully it will be fixed. Does not cost anything, worth a shot...
Yeah, seafoam is good also. The reason I say check the plugs is that the ticking could possibly be a loose plug getting ready to blow out of the head... A very bad thing... The torque spec is 7-13 pounds I believe.
The idle issues are related to the IAC IMHO.
Kilgore Trout said:
Yeah, seafoam is good also. The reason I say check the plugs is that the ticking could possibly be a loose plug getting ready to blow out of the head... A very bad thing... The torque spec is 13-17 pounds I believe.
My haynes says 7-13...
