  • SN95 4.6L Mustang Tech
Engine running rough at 1500-2000 RPMs.
  • Thread starter Thread starter 2002GreyGT
  • Start date Start date Apr 18, 2006
2002GreyGT
481
Raleigh, NC
Apr 18, 2006
  • Apr 18, 2006
So I have noticed this for a while, when I rev my engine to about 1500 to 2000 it runs REALLY rough. I can even feel it shaking the car. Anything over 2000 feels fine.
Any ideas on what it could be?
~K
Y
Yellow2002GT
148
Raeford, NC/ FT Bragg
Apr 18, 2006
  • Apr 18, 2006
I had the same problem......I used a bottle of seafoam and changed out my EGR......idles perfect now!
"ED"
Y
Yellow2002GT
148
Apr 18, 2006
  • Apr 18, 2006
Also....if your tuneable induction puts the maf closer or in the fender well you will need a pro-m meter to get a better reading for the sensor.....too far down stream and you need a better air meter and a good dyno tune!
"ED"
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Apr 18, 2006
  • Apr 18, 2006
~K
BUMP
Freakin weird! I was just about to start a thread about this same issue. If i just rev my car in neutral, it'll rev nice and smooth up to about 1300-1500 and then randomly gets rough to about 2000 RPM's and then smooths back out again. I can feel it a bit through the pedal but mostly through the seat.
the98stang
2,408
Clovis, CA
Apr 19, 2006
  • Apr 19, 2006
If it's missing maybe it's the plugs?
If the car is shaking it could be the D/S...
2002GreyGT
481
Raleigh, NC
Apr 19, 2006
  • Apr 19, 2006
the98stang,
Not to sound stupid, but what is a D/S? I check the acronym thread and it was not there.
I had my plugs changed maybe 15K miles ago, and Ford had to replace a Coil pack too then.
Is there a way to test you coil packs to see if they are good?
~K
jstreet0204
939
Winston Salem, NC
Apr 19, 2006
  • Apr 19, 2006
"ED"
This is not true. Clocking the MAF or putting a curve directly in front of it will skew the readings, but can be corrected with a tune. No need for a new meter.
2002GreyGT
481
Raleigh, NC
Apr 19, 2006
  • Apr 19, 2006
I am getting my programmer this week, so I can look into re-tuning everything.
Also, Ford said my MAF was out of spec a while ago, but that was after the CAI was on, and I bet it was just off due to the placement. Or that is what I am hoping.
~K
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Apr 19, 2006
  • Apr 19, 2006
Hmm, those are the two areas i'm targeting as well. But wouldnt the D/S vibrate at all rpm's
stng
182
#10
  • Apr 19, 2006
  • #10
Just a hunch, but I am inclined to think that you may have a "Flat Spot" on the TPS sensor.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Apr 19, 2006
#11
  • Apr 19, 2006
  • #11
Hmm never heard of this before. What should i look for?
the98stang
2,408
Clovis, CA
Apr 20, 2006
#12
  • Apr 20, 2006
  • #12
I'm not sure to be honest with you, but I have heard of cases where the drive shaft only vibrated during certain RPM's .
Another assumption...maybe the cats are vibrating? Mine do around certain RPM's when the engine is cold...
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Apr 20, 2006
#13
  • Apr 20, 2006
  • #13
No cats, O/R X-Pipe
the98stang
2,408
Clovis, CA
Apr 20, 2006
#14
  • Apr 20, 2006
  • #14
HoustonGT said:
No cats, O/R X-Pipe
Opps....forgot
Y
Yellow2002GT
148
Apr 21, 2006
#15
  • Apr 21, 2006
  • #15
Have you washed the engine lately...?? Sometimes water will get into the sparkplug resivoirs and foul them up....it happed to me before and ran fine at WOT but ran like crap in lower RPMS...! Just pull the Coils off and see if mositure is on them or if there brown at the bottom!
"ED"
Y
Yellow2002GT
148
Apr 21, 2006
#16
  • Apr 21, 2006
  • #16
I understand what you are saying but I have a AFM Power Pipe and my MAF sits about six inches down inside the fender well! Tried to tune it with an SCT dyno tune with the stock and then the C&L air meter and the signal just wasn't strong enough....with a tune......it would run but stall out and after contacting Rick at Anderson Ford it was said that the signal isn't strong enough past 16 inches from the TB with the stock meter.....the pro-m was strong enough to go upto 22 inches down stream!
"ED"
jstreet0204
939
Winston Salem, NC
Apr 21, 2006
#17
  • Apr 21, 2006
  • #17
"ED"
I see, but you have many more mods that would require a different MAF. A simple CAI will not.
dmontzsta
111
SoCal
Apr 21, 2006
#18
  • Apr 21, 2006
  • #18
Mine is a little shaky from about 1,000-1,300 rpm, then smoothes out. I just bought the car and need to get a FSM to check the resistance on stuff, I am going to change the plugs soon too.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
