Engine spins over but will not start / If spray gas into throttle body,will start and run ,but blows out pure black smoke both pipes / engine surges through all rpm ranges and will not idle /with ignition on new fuel pump runs but will nol shut off / 35-40psi fuel pressure /new fuel regulator (ignition on engine not running you can hear fuel passing through regulator
1989 mustang GT 5.0 FIVE SPEED manual
NEW FUEL PUMP / NEW REGULATOR /NEW TPS /IGNITION MODULE / NEW FUEL TANK /NEW OXYGEN SENSORS /
CAR WAS RUNNING! replaced broke valve spring and reassembled
started up right away but when driven shut off /psgr side cat converter got blood red.
NEED HELP! chng fuel reg twice purchased from autozone and advance NOT a ford regulator.
