  • SN95 4.6L Mustang Tech
Engine stalling
  • Thread starter Thread starter brownb2
  • Start date Start date Mar 14, 2012
brownb2
14
Maryland
Mar 14, 2012
  • Mar 14, 2012
I've been having this problem for about a year now I'll be driving and all of a sutten the motor dies I dont have a problem restarting the car but it will do it at all different speeds.
cl0udedth0ught
  • Mar 14, 2012
Any mods done to the car? How many miles? Any check engine lights on etc?....
brownb2
14
Maryland
Mar 14, 2012
  • Mar 14, 2012
It is a 02 gt Cai accel coils thats bout it had the car for about 2 1/2 years 110k on the dial
cl0udedth0ught
  • Mar 14, 2012
Have you tried scanning it for codes? You can take it to autozone and they will scan it for free. Off the top of my head... I would suggest its possibly an 02 sensor if they've never been changed.
brownb2
14
Maryland
Mar 14, 2012
  • Mar 14, 2012
I've got a handheld scanner and it has not thrown any codes and I just have to do emision test bout 3wks ago and it passed with no problems I never charge the o2 sensors
RedDaemon
3,470
9
108
Atlanta, GA
Mar 14, 2012
  • Mar 14, 2012
battery/grounding issue?
cl0udedth0ught
  • Mar 14, 2012
^ +1 good suggestion as well.
Does the car hesitate when you give it gas or does it have a miss or anything?
Its also possible that your car is not throwing a code. It wouldn't be the first time. Replacing the 02 sensors still might not be a bad idea since the car is over 100k.
brownb2
14
Maryland
Mar 15, 2012
  • Mar 15, 2012
Not all the time but I do get a miss at differnet rpm ranges. I also forgot to say I change the fuel filter wiith in the last 8months.
cl0udedth0ught
  • Mar 15, 2012
Have you changed the spark plugs yet? If you don't know if they've been changed by a previous owner, I would change them out with a new set of motorcraft plugs.
brownb2
14
Maryland
Mar 15, 2012
#10
  • Mar 15, 2012
  • #10
yup changed the plugs to motorcraft and coils and fuel filter the same day.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Mar 15, 2012
#11
  • Mar 15, 2012
  • #11
+1 on this as well. This is a PRIME symtom of a bad battery.
Just in case you thinking this couldn't possibily be a bad battery because the motor was running at the time, you are wrong. Today's car require the battery to excite the alternator's field coil.
no battery = no alternator.
brownb2
14
Maryland
Mar 15, 2012
#12
  • Mar 15, 2012
  • #12
Thanks I will check the grounds and the battery this weekend and give you guys an update thanks.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
