  • SN95 4.6L Mustang Tech
Engine Swap
  • Thread starter Thread starter 88Stang13
  • Start date Start date Dec 3, 2007
88Stang13
  • Dec 3, 2007
Has any one ever heard/have any info on swapping a 4.6/281 with a 5.8/351? I have been interested in doing this to my vehicle, but I couldn't find any info on it.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Dec 3, 2007
  • Dec 3, 2007
Well, most likely you will haveto go with a carbed setup. All I can tell you is to take all the underhood wiring out. Drop in a 5.8L and wire it all custom. MSD ignitions, run new custom fuel lines/pump. Decide weather to keep the gas tank or go fuel cell. Not too many people do this....most now are doing modswaps. (Modular motors in fox bodies.)
2000fordstanggt
404
Westland, MI
Dec 3, 2007
  • Dec 3, 2007
prolly a 94-95 k-member too
R
r3dn3ck
39
  • Dec 4, 2007
one of the few cases where it's easier and cheaper to do a 5.4L swap. See linky below.
http://www.mustangboards.com/modula...ested-5-4l-swaps-here-need-you-opine-105.html
SVT32VDOHC
3,501
28
119
Motor City
Dec 5, 2007
  • Dec 5, 2007
YEAH 95-95 k frame a must. Overlooked that point!!
the_tool_man
17
Spartanburg, SC
Dec 5, 2007
  • Dec 5, 2007
I would think you could do it using the parts from a 5.0L SN95 Mustang: K-member, motor mounts, bellhousing, etc. Assuming you're talking about a 351 Windsor, it's the same as a 302 but with a taller deck height. Ford did it in 1995 with the Cobra R. No need for carb or homemade intake & exhaust at all.
Regards,
John.
88Stang13
  • Dec 6, 2007
I am talking about a 351 windsor. I want to go carb with it. Just curios. I did notice that they put in in a saleen s351 as well. I just wanted to know if it was possible and if it was what all was involved. Do you think that I would have any clearance problems with a stock hood.
the_tool_man
17
Spartanburg, SC
Dec 6, 2007
  • Dec 6, 2007
I can't say for sure, but the '95 R used a taller hood for clearance, so I doubt a stock hood would work without lowering the engine mounting position. I have read where people installing a 5.4L use spacers to lower the k-member, effectively lowering the engine in the chassis. They then use a set of lowering springs to restore proper ride height, at the expense of suspension travel. I think the '00 Cobra R did exactly that from the factory.
This sounds like a fun project. Good luck.
Regards,
John.
40th GT
916
Lawrenceville, GA
Dec 7, 2007
  • Dec 7, 2007
If you decide to do this let us know how it goes. And good luck to you.
R
r3dn3ck
39
#10
  • Dec 7, 2007
  • #10
no dropping of the k-member with a 2v 5.4 swap. Adapter plates and PI intake fits under the stock hood with a tiny clearance of the hood subframe. The new HPS 5.4 intake will clear a stock hood.
Dropping the k-member about .4" makes a 4v 5.4 swap a lot easier to deal with. If you use spacers to drop the k-member the tranny mount needs to be dropped too but a bit less. Correct application of trigonometry will determine the tranny mount drop for your trans.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Nov 1, 2026
LILCBRA
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
DadLife0724
