Engine Ticking Sound
  • Thread starter Thread starter dupont
  • Start date Start date Sep 22, 2012
D
dupont
29
  • Sep 22, 2012
My gas pedal got stuck under my mat and it revved all the the way up for a couple seconds. Now it run and drives as normal but there is a ticking sound from the engine. It sounds like the passenger side closest to the firewall. I dont know what it is. I tried to tighten the header bolts but they weren't loose. I think its a valve spring or a push rod?
darthcual
985
Arlington, TX
Sep 22, 2012
  • Sep 22, 2012
Did you maybe float a valve? Is it blowing smoke? That or a sticking lifter.
D
dupont
29
  • Sep 22, 2012
It's not blowing smoke, and it runs the same as before it happened
darthcual
985
Arlington, TX
Sep 22, 2012
  • Sep 22, 2012
Sounds like a sticking lifter then. Keep an ear out for it, to see if it gets worse.
D
dupont
29
  • Sep 22, 2012
Is there any way to unstick it?
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 25, 2012
  • Sep 25, 2012
WOT??? Spun bearing?
darthcual
985
Arlington, TX
Sep 25, 2012
  • Sep 25, 2012
Yeah, change them out. Some have had luck with a heavy detergent oil like tranny oil. It didn't work for me though. Just living with it until I can change them.
gearheadboy
1,425
177
84
Greencastle Pa
Sep 26, 2012
  • Sep 26, 2012
Oil change with a synthetic and some Marvel Mystery Oil or Sea Foam. Run it a while. Thats if its a lifter. I'd be looking at a header gasket though. Just as likely.
88LX5.Oh
1,442
205
94
Arkansas
Sep 26, 2012
  • Sep 26, 2012
Just because the bolts don't tighten doesn't mean you didn't blow the gasket out.
Reactions: gearheadboy
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 26, 2012
#10
  • Sep 26, 2012
  • #10
Take a wooden handle - like one from a plunger and one end to your ear the other end along valve cover on that side. See if you can isolate where the noise is coming from. Pour a few ounces of MMO in and see if the tick goes away in a few hundred miles. Sounds like a lifter may have bottomed out or stuck.
88LX5.Oh
1,442
205
94
Arkansas
Sep 26, 2012
#11
  • Sep 26, 2012
  • #11
Holy crap. I thought I was the only person to use weird methods to locate noises. I use pieces of hose against my ear. The noise gets funneled and amplified along the way up to your ear lol
Reactions: Cory Berg
D
dupont
29
#12
  • Sep 27, 2012
  • #12
I think its actually where the header and exhaust meets
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 27, 2012
#13
  • Sep 27, 2012
  • #13
HA! I bet your tool box looks like mine. I have a whole drawer full of "custom" made tools, gauges, etc. My wife calls me McGiver. lol
To the OP are you saying now the tick is coming from where the header collector bolts to the intermediate pipe? odd...... did the hose from the exhaust pipe to the smog pump hose get loose?
Unknown engine tick
  • 94 Daily
  • Oct 31, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 1, 2025
91AOD5.0LX
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
