Estimate my 347's HP
  • Thread starter Thread starter thekid760
  • Start date Start date Aug 16, 2007
T
thekid760
114
  • Aug 16, 2007
My engine setup:
347 kit w/ 5.4 rods, cast steel crank, and Speed Pro hyperutectic pistons.
1978 302 non roller block bored .030 over and clearanced for crank
Stock 78 heads rebuild, and mildly ported by me
1.6 roller rockers
RPM air gap intake
Holly 650 DP carb with mechanical secondaries
Isky solid mech cam Part#: 381358 278 adv duration 244 @.050 .512 lift 108 degree centerline
Hi volume oil pump
stock pan
1 5/8 long tube ceramic coated headers
MSD pro billet distributor
6al ignition box
What would you estimate my setup would make?
This will eventually be paired to an AOD w/ 3000rpm stall and 3.73 rear gears.
Any comments or suggestions?
Sevan
558
IL
Aug 17, 2007
  • Aug 17, 2007
somewhere around 350 (+/-) at the crank, this is just a guesstimate...get it dyno'd when ur ready then ull know....good luck
Wallzy
128
Orlando, FL
Aug 17, 2007
  • Aug 17, 2007
Why is it that we play this guessing game? There are so many other factors than what you listed. It seems like everyweek someone is asking, "How much power will this make" or "What will my car run if i have this." Don't use the search engine and read? Every question that i have ever needed has been asked about 5x on this forum and out on the internet. Sorry for venting.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Aug 17, 2007
  • Aug 17, 2007
I'm not going to guess on your power but I will tell you that IMO the heads have got to go. Those will choke your 347 stroker. I do not think with those heads you will see 300+ hp.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Aug 17, 2007
  • Aug 17, 2007
1 million H.P.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Aug 17, 2007
  • Aug 17, 2007
BK_CAULEY said:
1 million H.P.
thats funny right there I don't care who you are thats funny right there.
twistedwankel
200
Spring Hill, FL
Aug 17, 2007
  • Aug 17, 2007
http://www.wallaceracing.com/Calculators.htm
Put it together and run the numbers against these calculators.
Then you will know what you have at your wheels.
Otherwise buy a shelf motor that they have all ready tested and will guarantee.
The answer to your question is: Zero HP as it will never run.
tkareno
67
clinton ct
Aug 17, 2007
  • Aug 17, 2007
350 mayb more
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 17, 2007
  • Aug 17, 2007
If you are on a budget, why not get a set of GT-40s or GT-40p's and have them ported? Those '78 heads were designed around fuel economy and low emissions, not performance.
85ragtop
BTW, I like dudes.
475
123
NC
Aug 17, 2007
#10
  • Aug 17, 2007
  • #10
How much HP not tech.
Moved to talk.
$uperstang
476
Detroit, MI
Aug 17, 2007
#11
  • Aug 17, 2007
  • #11
300RWHP 340rwtq is my guess
T
thekid760
114
#12
  • Aug 17, 2007
  • #12
I understand where you are coming from, but keep in mind that every engine setup is different, thats why I was not only requesting the guesstimated HP, but also any comments or suggestions pertaining to my setup.
Thanks for the advice, thats what i'm looking for. How much should I expect to pay for for a ported set?
Whats the difference between the GT-40's and the GT-40P's?
I was thinking about just using this setup for now and when I save up enough money, I'll replace then with some AFR 185cc's.
I ran this engine setup through Engine analyzer Pro using stock heads w/ 10cfm more airflow throughout the lift range.
348hp@5250rpm & 370tq@4250rpm
That sounds about right from what you all were guessing.
Other than the heads (which I know is a huge restriction) is there anything else that you can see problems with in my combination?
By the way, I was told with the current piston/head combo I should have around 10.7:1 CR.
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Aug 17, 2007
#13
  • Aug 17, 2007
  • #13
It would be easier just to dyno it and put the guessing game to the side. If anything I would make a thread asking what I could do with my current set up to get more out of it or what mods I could do to see better performance.
So, with that said. I'm guessing 97hp 78tq.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 17, 2007
#14
  • Aug 17, 2007
  • #14
I got a very nice set of ported GT-40's with FRPP 1.6 roller rockers on ebay for about $600.
You should be able to get bare 40's or 40P's for $200-$300. Or, just go to the local pick and pull and find a 98-00 Explorer (I believe that's right, double check though) for a set of 40P's.
GT-40Ps flow better than GT-40s but have a spark plug angle that limits your header choices. Either set with a good port job can scream.
N
niklid05
140
Kutztown PA 19530
Aug 17, 2007
#15
  • Aug 17, 2007
  • #15
260 to the LF and RR.
T
thekid760
114
#16
  • Aug 17, 2007
  • #16
That might be fun doing donuts with
But seriously guys, I know it's near impossible to predict horsepower for a given combination considering all variables, if that were the case then we wouldn't need dyno's.
I think I'm more asking if anyone can see any major flaws in my combination, and if so would you mind providing me with some positive criticism.
I know the heads are my bottleneck right now, but those will be addressed in the future, so for now they'll have to do, not enough $$ in the budget for them.
A
  • Locked
92 347 Bimini Blue Notchback F/S
  • AFfoxbody78
  • Oct 20, 2011
6K
Fox Body Mustangs For Sale (1979-93) Jan 29, 2012
TexasFireman
T
  • thekid760
  • Aug 16, 2007
Classic Mustang Specific Tech Aug 21, 2007
Cyclone
  • Locked
TURN-KEY TURBO BIG BORE 347 DSS AFR 614 RWHP/657 RWTQ
  • speedshifter
  • Feb 6, 2011
  • Engine and Power Adder Parts
8K
Engine and Power Adder Parts Feb 27, 2011
speedshifter
  • Locked
FS: 1993 LX 5.0 347 stroker reef blue/black int.
  • 87nitemare
  • Mar 9, 2010
19K
Fox Body Mustangs For Sale (1979-93) May 19, 2010
87nitemare
I
go to dyno on sat. any guesses??
  • iapexl8r
  • Dec 14, 2007
1965 - 1973 Classic Mustangs -General/Talk- Dec 21, 2007
iskwezm
