92 347 Bimini Blue Notchback F/S
super clean notchback LX original 5.0/ 5spd car, Bimini Blue, 108k miles on chassis/ 1,600 miles on motor/ trans. Runs/ looks great. Selling because I'm looking to get into a 2003-04 cobra coupe. Direct questions/ offers to [email protected]
Mods:
347 shortblock (seasoned stock block) 108,XXX miles on chassis and 1,600 miles on motor/tranny.
347 (short rod) stock block
arp main studs
Crank:scat cast steel 3.4" crankshaft 28oz
Rods: scat 5140 Forged I beam 5.315"
Bearings: Clevite P rod/main
Pistons: Probe SRS 2618-t6 high alloy lightweight forged pistons, Flat top (10.79:1 w/60cc), TRICK FLOW VALVE REL
Rings: Speed Pro high performance ductile iron
new oil pump and arp oil shaft
28 oz Balance 28oz billet flywheel
Trickflow TW heads
Trickflow R intake
Comp XFI236HR cam 326int 248exh-.579, .579
Autometer Phantom Fuel Pressure and Boost gauge ( above radio )
Innovate LM1 wideband
American Muscle Fenderwell CAI
Trickflow R intake with 1" spacer
Twisted Wedge Heads (older castings dont say Trickflow on the front)
1.6 Ford Racing Roller Rockers
hardend pushrods
Comp XFI236HR Cam (236int-248exh--.579-.579 lift)
Mac 70mm Throttle Body
FRPP 30# injectors
Energy Suspension Motor and Trans Mount
BBK Longtube headers
BBK 2.5" X pipe
Dynomax ultraflow catback
aeromotive fuel pressure regulator
255lph intank fuel pump
Vortech T Rex external fuel pump
Fidanza billet steel flywheel
Centerforce DualFriction clutch
TKO500 trans 26spl version
UPR shifter handle
FRPP Alum driveshaft
Spicer Yoke
FRPP 3.73 gears
Trickflow stud girdle
Moser 31spl axles
truck diff
megabite sr lift bars
double adj uppers
Strange 10way shocks and struts
4cyl springs on all corners
Weld Rodlite wheels 4"fronts 8" rears 5.5 lbs
electric fuel pressure gauge
MSD 6al and coil
C&L 76mm maf
extra C&L 76mm
SCT elimintator chip (not installed)
Asking $7500 OBO
Here's some pics i have that i took with my iPhone
DSLR pics this weekend
thanks
more
the 1/4 glass trim is in good shape as is the body side moldings. there is fading on the moldings as they are original paint.
VIN # 1FACP40E0NF106177
these are the only bad things about the body
-crack in the bumper cover
-paint damage from previous owner( probably brake fluid)
