  • SN95 4.6L Mustang Tech
EVAP problem
  • Thread starter Thread starter bhuff30
  • Start date Start date Jan 28, 2007
bhuff30
6,037
35
129
Olathe KS
Jan 28, 2007
  • Jan 28, 2007
I've got a 97 GT and the CEL is intermittently coming on. Oddly enough, it also sometimes turns off without me clearing the code.
Anyway, it comes back with code P1443. This is for the evaporative purge valve.
My question, is this a common problem or one that anyone has experienced before? I've got a whole list of things to start checking from the service manual, but if anyone has experince with this or it is a common problem, that could save me a good deal of time.
Thanks,
Brian
sgarlic
3,085
Jan 29, 2007
  • Jan 29, 2007
Easiest one relating to evap codes is replace the gas cap. You can also check for blockage or damage to any of the evap lines, but good luck finding that without knowing what to look for.
J
jtroush2002
41
please ship to: Irving, TX
Jan 29, 2007
  • Jan 29, 2007
agree
first check your gas cap
then check your fuses...CJB(under dash) #2 and #8 if these are blown they you have a short somewhere
if they are ok then check the purge valve itself and current flow to it.
Purge Valve is underneath the right fender
check this and update us
RandyStinchcomb
1,159
Randallstown, Md
Jan 29, 2007
  • Jan 29, 2007
Thanks,
Brian
easy to fix, 2 parts cause this problem. 1 is the cainster purge valve, part # E6ZZ-9C915-A and the thermistor probe part # F57Z-14A606-BA, both parts should run @$60.00 and this is a commomn problem on 1997 back Ford cars and lt trucks
bhuff30
6,037
35
129
Olathe KS
Jan 29, 2007
  • Jan 29, 2007
Thanks for the info. I did see these part numbers after searching the forums, but I'm not excited about spending 60$ on a problem that has no effect on driveablity or milage or anything else I'd notice. I may test each sensor to see if one or another is bad, or even see if this part cross references to a 98+ mustang and get a used but good parts.
RandyStinchcomb
1,159
Randallstown, Md
Jan 29, 2007
  • Jan 29, 2007
1998 up uses a different Evap system and different parts and yes, this will cause some loss of performance if not corrected
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
