exhaust help???
  • Thread starter Thread starter 91green5.0
  • Start date Start date Jan 21, 2008
91green5.0
33
Middle Granville NY
Jan 21, 2008
  • Jan 21, 2008
My 91 GT has stock headers an off road H and flowmaster catback and I really like the sound of it but I was thinking of going with an X pipe. Im sure there are a lot of threads on here about it but i didnt see much. Is there a real difference in power or sound. I also was wondering if anyone could help me with headers my last 5.0 had mac shorties on it and i like them but was wondering if equal length would be a better choice. Thanks for any help.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jan 21, 2008
  • Jan 21, 2008
the x pipe will have a slightly different sound. not so much of a rumble like an H, more of a raspy sort of sound. but its not really all that much different honestly.
as for the headers, on a mildly modified engine, the difference b/w equals and unequal is pretty much nothing. except the equals take up more room. i had a set of cheapy flowtech equals ( old set) and they were routed different than most brands, and it stuck out so far it got my clutch cable too hot and screwed the cable all up.
the difference from H to X isnt much IMO. if you want a difference in sound try some different mufflers.
Sicarius428
2,085
Jan 21, 2008
  • Jan 21, 2008
As far as exhaust for a street car, the power difference between any of those is very little. What will effect you more is how much air you can get into the motor. The stock headers are ok up to 280-300ish hp. The only real gain is to go with long tubes as opposed to equal and non equal lenght shorties. You already got rid of the cats so that would be the first thing that would limit your flow... especially the old style ones. It sounds like you are going to be redoing everything but the catback. If you are looking for the most power, consider long tubes. As far as x vs h there really isn't a difference on a 300ish hp car. Mostly for sound... The H will give you that old school muscle car sound and the x will give you the nascar sound. FYI, exhaust has to be one of the worse power per dollar improvements.
Kevin
NKau
1,346
Jefferson, WI
Jan 21, 2008
  • Jan 21, 2008
On a stock motored car, there really won't be a power difference between the two. There are gains to be had choosing an x-pipe over an h-pipe in higher HP applications though.
That being said, the x-pipe definitely has a raspier more exotic sound, v.s. the deep rumble of an h-pipe. I have had both, and like both.
bloopbloob
578
Alberta
Jan 22, 2008
  • Jan 22, 2008
you won't see much difference from anything if you're still fairly stock otherwise. i have long tubes with an o/r x-pipe, and it actually quietened the exhaust down quite a bit, and i couldn't feel any real power difference after the swap.... now i sometimes think i should have gone with an h-pipe because i miss the deeper note....
91green5.0
33
Middle Granville NY
Jan 22, 2008
  • Jan 22, 2008
Thanks for all the help guys. I like the sound of my H pipe so i dont imagine that I will change it. I had the unequals before and they were just fine. I didnt notice a real power difference but i only drove it about 200 miles before i put them on, ceramic coated macs got them barely used for 100 bucks they still looked new so i couldnt pass it up. For what ill do with this thing im sure i wont need long tubes i just want a little bit. I already have an interesting air intake i havent seen it used my stock airbox but theres a tube that goes to underneith the fog light and i havent seen that but only on the LX.
W
Dipstick
  • wccurtis1963
  • Jun 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
Willybill32
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
J
4 bank eliminator chip
  • JJ's90fox
  • Feb 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
AeroCoupe
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
