Exhaust Smells Rich, Problem??
  • Thread starter Thread starter 90GTSilverStang
  • Start date Start date Dec 2, 2006
9
90GTSilverStang
15
  • Dec 2, 2006
The car is a 90gt vert Basically stock except for off road H pipe, shorty headers, flowmaster catbacks. I don't have cats. No check engine light. The exhaust smells like its running real rich. could it be I need a adjustable fuel pressure regulator to lower the fuel pressure? Anyone with the same problem? Engine runs well.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 2, 2006
  • Dec 2, 2006
No cats means your HC (hydrocarbons=unburned gas) will be higher, hence the smelling rich. If you're really concerned, you could pull codes, but 99% of the time, it's going to smell rich after removing the cats.
onefstsnake
792
Northern VA
Dec 2, 2006
  • Dec 2, 2006
yeah mine runs a little richer now that I have an O/R H on mine.
The bumper gets dirty real quick too...
Its not going to hurt anything but gas mileage...
My A/F at 5K rpm was 11.9 : 1 lol
9
90GTSilverStang
15
  • Dec 2, 2006
what is considered a good A/F Ratio? Through 6k RPM's.
O
OrLackThereof
560
Palm Bay, FL
Dec 2, 2006
  • Dec 2, 2006
11.9:1 is too rich for an N/A app. I'd look for the high-end of 12:1. I run about 12.9:1 WOT, NA with heads cam etc.
onefstsnake
792
Northern VA
Dec 2, 2006
  • Dec 2, 2006
my shop told me that most 5.0's run rich w/o tuning.
probably just something ford did to get the engines to last a little longer and avoid detonation.
I wouldnt touch the FP regulator till you get it on a dyno.
but like I said, running rich is only gunna hurt your gas mileage.
MUSTANGJOE
Silver Stanger
1,644
17
59
Dec 2, 2006
  • Dec 2, 2006
Mine smelled like it was running rich after I installed my h-pipe. Actually every car that has an off road H smells rich!
HISSIN50
34
129
Dec 3, 2006
  • Dec 3, 2006
I agree - even a car with spot-on stoichiometry tends to smell stinky with no cats. Our noses aren't all that accurate for determining A/F ratios.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 3, 2006
  • Dec 3, 2006
Your O2 sensors may be on the old side.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
onefstsnake
792
Northern VA
Dec 3, 2006
#10
  • Dec 3, 2006
  • #10
My O2 sensors were new when I changed the Hpipe.
O
OrLackThereof
560
Palm Bay, FL
Dec 3, 2006
#11
  • Dec 3, 2006
  • #11
My A/F is spot-on, and I run a catless X pipe and dumps, and my car hardly smells at all. Believe me or not, but I dialed my A/F in by ear, nose, and seat of pants...kept adding/removing fuel in 0.5 psi increments and driving it, until it didnt stink and felt not....sloppy....but not jagged either. Hard to put into words, but you can feel the motor through the gas pedal...if you tip in and it feels harsh or rough, it's lean...if it feels squishy and soft, it's rich. Doing that, I got it on a wideband after and A/F was 12.9:1.
Im not saying everybody can do it, and it takes a lot of time and plug-reading and whatnot, but it'll save ya some money. Hell how do you think they did it before widebands?
9
90GTSilverStang
15
#12
  • Dec 3, 2006
  • #12
Hissin50, I've read a few of your posts and I am not going to change the FPR. One of your post read that if you lower the fuel pressure the computer makes up for it by widening the pulse width to the injectors and effectively nothing has really changed. So I will first check the codes. But-- How does one dial in the A/F ratio to tune it in? I read about the Tweecer but what is it?
HISSIN50
34
129
Dec 3, 2006
#13
  • Dec 3, 2006
  • #13
For your situation, I'd tend to agree that an AFPR is not going to help (there are times when it can indeed help).
You hit the nail on the head - you'd need a handheld (TwEECer, PMS, etc), chip, stand-alone system, or other device to tune the AF ratio. For most-all except the chip route, you'd need a wideband to see what's going on. A laptop helps in many cases as well.
I'd note that this is all just a little overboard for a mild bolt-on car. Installing some nice high-flow aftermarket cats would likely cut down on the eye wattering/fuel stink. If things were getting out of kilter and truely too rich, the puter would try to lean the system down and you'd see adaptive limit codes (hitting the lean adaptive limit; system rich).
Random thoughts.
Good luck.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
