Exhaust
  • Thread starter Thread starter mustanglx91
  • Start date Start date Sep 22, 2007
mustanglx91
56
Wilkes-Barre PA
Sep 22, 2007
  • Sep 22, 2007
Side Exit Exhaust
I have a 1991 5.0 lx and was wondering who makes a side exit cat back or any type of side exit exhaust that exits in front of the rear tires?
Thanks
jcw88
Never played w/ it before so i'm still a virgin!
Mar 20, 2007
53
fernandina, fl
Sep 22, 2007
  • Sep 22, 2007
i posted a thread asking the same thing but i don't think that a fox can. the mufflers mount to close to the back axle and it would take a pretty hard bend that wouldn't benefit . but i would like to see it done think it would really look good!!
mustanglx91
56
Wilkes-Barre PA
Sep 22, 2007
  • Sep 22, 2007
I found one. But you have to cut out the support rails on the sides of the car and weld the ones they supply. Other wise the pipes wont fit.
L
lang williams
567
cleveland, oh
Sep 22, 2007
  • Sep 22, 2007
i put a spintech side exit on my 87 notch, it was for a 94/95 so it stuck out a little far, i just cut tips off an put shorter ones on. if your driveway has a high curb or you go over large speed bumps the spin tech one will drag though.
O
one_bad_5.0
New York
Sep 22, 2007
  • Sep 22, 2007
Check CJ Pony Parts. I think I've seen a Fox kit in one of their catologs. Look them up and call them.
mustanglx91
56
Wilkes-Barre PA
Sep 25, 2007
  • Sep 25, 2007
I E-mailed them and they dont have one.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Sep 25, 2007
  • Sep 25, 2007
Spintech does, but to be honest I dont see the point. I have mine dumped before the axle, and would do that 100 times over before running it out the side.
88GTStreetRod
376
USA
Sep 25, 2007
  • Sep 25, 2007
I had the spintech side exit kit on my 88. You really need the spintech sub frames to make the kit fit right. With long tubes, off road h-pipe and a nice cam, the kit sounds "NASTY" buying another set for my current set up. Very unique sound. I think exploding gopher on this site saved the sound clip of my car.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Sep 25, 2007
  • Sep 25, 2007
I had a side-exit setup I fabbed on my notch last year with a couple of same-side inlet/outlet Dynomax 2.5" muffs (part number was something like #17676 or something like that). I wasn't crazy about the way it sounded with an off-road X-pipe ahead of it - it sounded WAY better when I had an off-road H-pipe ahead of it on my prior notch - and constantly fighting the ground clearance issue was more of a PITA than it was worth. I'm glad I kept my Dynomax stainless tails and Pypes Violator muffs...
mustanglx91
56
Wilkes-Barre PA
Sep 28, 2007
#10
  • Sep 28, 2007
  • #10
So then there is no easy way to get one and even if I do I'm going to have clearances issuses .
gtstang86
55
California
Sep 28, 2007
#11
  • Sep 28, 2007
  • #11
check you local muffler shop. they can usually setup something custom for. you can pick out your tips and everything.
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Sep 28, 2007
#12
  • Sep 28, 2007
  • #12
Three ways to go about making a side-exit setup:
1. Use a standard offset inleft/center outlet muffler, put a 180* U-bend behind it, then a 90* elbow to put it out to the side. Looks weird under the car, potentially more restrictive than a standard rear-exit setup.
2. The Dynomax #17676 same-side inlet/oulet muffs like I used, just add a 90* elbow on each, plus an extension, and you're done. Looks kinda weird, though, unless you put some kinda groovy slash-cut tips on it, and it sounds kinda ugly behind an off-road X-pipe (however, it does sound VERY nice behind an off-road H-pipe - not as "poppy," more of an old-school Mopar kinda rumble).
3. Use a couple of 45* elbows right after the fllange off your X- or H-pipe, clamp/weld on some short and simple tube muffs (glasspacks, Race Magnum Bullets, Moroso Spiral Flows, whatever), and shoot 'em out the sides at an angle. Probably the least amount of ground clearance allowed, and HELLA loud, but probably the least restrictive exhaust you can make next to dumps, and you don't gag from the fumes pooling up under your chassis like you would with dumps. Probably best used on a car with a jacked-up rear for tall tires or something.
With ANY side-exit exhaust, you're gonna have to deal with a LOT of increased sound (not always a good thing - mine was obnoxiously loud inside, even with the windows up), ground clearance problems, and fumes drifting into the cabin at every single stoplight no matter which way the wind is blowing outside. You can tuck the exhaust up as high as possible to help with clearance, but then you're going to run into problems with the tailpipes hitting the floorboards and/or being in close proximity to the brake and fuel lines (you'd best be insulating/shielding them, in that case).
Hit something exiting
  • Creomod
  • Mar 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
General karthief
Interior and Upholstery Water leak, passenger side, ripped seats and carpet out already.
  • 2000ElectricGreen
  • Mar 18, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
squeak93
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
