Exhuast leak need help FAST!!!
SFgiants25
65
Lakeland
Hey guys, Well i just got my Mac offroad hpipe intsalled with 2 chamber flows. I can't seem to get the driver side part of the pipe to seal correctly with the Manifold. Any body else have this problem??? Any suggestions to fix the problem??? The exhuast place i went to today was tryin to rip me off tellin me they wanna put new bolts in the manifold etc etc, then if that dont work cut off 1ft of the H pipe, and weld in there own crap and bolt it to the manifold usin 2 1/4 pipeing :rolleyes: Please help ASAP
When I had my stock manifolds on i had to put new studs in because the stock studs have spacers on them that kept me from being able to tighten the bolts enough to create a seal. I think i bought the studs from either Napa or autozone can't remember. Kinda of a pain to get them out. I just used some vicegrips and turned the hell out of them till they came out only on diverside though
i have had my h-pipe on for a year now and has been leaking since day one. I have replaced the studs and that will work for a few days but then they will work loose and you will have to keep re tightening them. Just get used to the leak because i have had every exhaust shop in my area try to fix and it seems almost impossible unless you just get it welded. :( :notnice:
replace the studs , take the gasket if a paper type to a parts store and get one matched up that will cover the entire flange that is made of a metal type material unless your pipe came with a metal type gasket , alot of companies send thick paper ones that seal great but wont hold much pressure , use hardened studs , lock washers , blue loctite and brass nuts . Also , tighten up the passenger side last
Well yall are a big relief for me. I'll definitlly get some new studs Cause that noise is drivin me up the wall I have to turn my radio up so i dont hear the leak over my exhaust. I can't wait till I Hear juts the exhaust. So far the sound is Amazing just what I wanted. So many compliments allready even with the leak. But i really Appreciate the help fellas looks like i got something to do tomorrow :D
Header bolts
Your pipe wont snug down because of the factory header bolts. Remove the factory header bolts using the "two nut removal method". Then replace bolts with NAPA part #600-1819 manifold bolts.
Fixed!!!
