Experts needed: Turbo swap on '93
My Black Beast
83
Lakeland, FL
Hey guys, I did my swap last summer and haven't been able to get the car running. :( I finally have the time to look into it. I used Stinger's website but I noticed that my wire colors were very different so I used my Ford wiring diagrams to figure out which wires were what. I have triple checked all of them.
Problem: The dash lights turn on with the key but it will not crank. Also the fuel pump does not turn on with the key.
Should the car still try to crank if the fuel pump isn't turning on? How can I check to see if the ignition is working? Any ideas of where to start would be great. Thanks,
Mike
Thanks for the quick reply. When I turn the key into the ON position the Brake Light and airbag light comes on and the gauges move. When I turn the key as if starting it, the Check Engine light and brake light comes on. Is this what you were talking about.
Mike
