Explorer 8.8 Rearend???
  • Thread starter Thread starter horseballz
  • Start date Start date May 26, 2010
horseballz
824
Las Vegas, NV
May 26, 2010
  • May 26, 2010
Hi Folks,
What year did the Explorers start with rear disc brakes and what year started the 8.8". I would prefer, at this time, to go with rear drum brakes, as I'm already plumbed with new disc/drum master and proportioning valve etc. and just now finding that my 8" is pretty pooched. If looking for drums, trac-loc and a favorable gear ratio (3.40-3.80) would I be just as well off to look at Rangers? I assume the best bet for trac-loc would be in a 4X4? What ratios were offered in the Rangers? Any and all help is appreciated.
Thanx,
Gene
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
May 26, 2010
  • May 26, 2010
I'm in the same situation. The fox body mustangs had a 9" drum just like the stock 67' to 73' rearends and its only a 1/4" wider on each side. plus there's no offset in the pumpkin. This is what I'm planning on using. just get a rear from a gen 3 mustang and do a 5 lug conversion, different axels and different drums and your ready to go!
9
96 DOHC Cobra
542
Cerritos, CA
May 27, 2010
  • May 27, 2010
91-94 Explorers had rear drums. 95-up have rear discs. 2002-up have independent rears. I wouldn't bother with a Ranger rearend. I've heard that some came with 31 spline axles, but I'm sure none prior to 2000 did. They're all 28 spline in all ratios from 3.07 up to 4.10. I've seen printed material that shows a 4.56 was available, but I've never actually seen one. Traction loks are hit and miss whether in a 4 X 2 or a 4 X 4.
The Explorer is another story. ALL are 31 spline. I've seen them with ratios from 3.27 up to 4.10 with and without traction lok. Better than 90% of them seem to come with 3.73s and traction lok.
horseballz
824
Las Vegas, NV
May 27, 2010
  • May 27, 2010
96 DOHC Cobra,
Please explain to me why 31 spline axles are good and 28 spline axles are bad? Bear in mind that this car is being put together as a mostly highway cruiser and will likely never see a drag strip. Also, do the 8.8" rears generally have tags on them that are easy enough to decipher to figure out ratio and whether trac-loc or not?
Thanks,
Gene
9
96 DOHC Cobra
542
Cerritos, CA
May 27, 2010
  • May 27, 2010
There's nothing wrong with 28 spline axles, but 31 spline are better. If you buy the rearend from a wrecking yard, the Explorer rear will cost the same as a Ranger rear. They all come from the factory with a tag bolted to the rear cover. It tells you all the same info that the tags on the 8" and 9" do. The most important part is it tells you the ratio and whether it's open or traction lok. 3.73 = 3.73:1 ratio and open. 3L73 = 3.73:1 ratio with traction lok for example.
Loup-garou
337
New Orleans, LA
May 30, 2010
  • May 30, 2010
Keep in mind that the pinion location on an Explorer 8.8 is offset more than in the older designs (as used in the Mustang). Some people have found that the "long side" of the 8.8 housing could be shortened to center the pinion. That enables a second short-side axle shaft to be used, eliminating the need to buy something custom-made.
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
C
Help identifying 8.8
  • Caden_H
  • Jun 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 12, 2025
limp
R
8.8 rear end for '67 coupe, shortened - next steps
  • rubendenver
  • Dec 15, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
I don know what im doing!
  • Sha_lala_pookie
  • May 5, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 11, 2025
Sha_lala_pookie
