Explorer serpentine pws alt ac bracket D Hearne Help!!
  • Thread starter Thread starter dbfarr
  • Start date Start date Jan 31, 2009
dbfarr
191
Boise ID
Jan 31, 2009
  • Jan 31, 2009
I've got a 96 exploder engine, I've already purchased the balancer and water pump for the explorer... But I went to the yards today, seems they just recycle the bracket.
Even more annoying, they told me if the had it, they'd want $65, meanwhile they get what, $1.50 for it when they recycle it
Anyway, I need to source the bracket and a pws pump, any ideas about alternate models that will provide the compact accessory system.
Maybe someone has this stuff sitting around collecting dust?
D Hearne, any suggestions.
Don
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Jan 31, 2009
  • Jan 31, 2009
THIS GUY PARTS OUT CARS AND HAS SOME 96 XXPLORERS, HE SAID TO CALL HIM
http://stores.ebay.com/Great-Deals-For-You-Too
D
D.Hearne
11,730
south louisiana
Feb 1, 2009
  • Feb 1, 2009
The Explorer/Mountaieer accessory setups were unique unto themselves, the only part of these setups that interchanged with any other vehicles that I know of was the timing cover. You're not clear on what bracket you're talking about either.
dbfarr
191
Boise ID
Feb 1, 2009
  • Feb 1, 2009
All I have right now would be,
96 Explorer timing cover
96 explorer damper, with pulley attached
96 explorer Water Pump and pulley
So I guess i need the Power steering bracket, the Alt bracket, and the tensioners
woodsnake
1,352
15
69
Hicksville, NY
Feb 1, 2009
  • Feb 1, 2009
Go buy a camaro, it's easier..........
dbfarr
191
Boise ID
Feb 1, 2009
  • Feb 1, 2009
Do they make them in pink?
D
D.Hearne
11,730
south louisiana
Feb 1, 2009
  • Feb 1, 2009
From what I understand, the accessories bolt directly to the cylinder heads, on the Explorer/Mountaineer and the 94-95 Stang (it would also apply to the 88-93 T-Bird/Cougars as well, the 94-95 Stang setup was borrowed from those applications) I haven't had access to these setups to study them though so I cannot tell you for sure that this is true.
stonecoldtx
214
Dallas, TX
Feb 2, 2009
  • Feb 2, 2009
I have all this stuff if you want it . . . brackets, P/S pump, A/C compressor and alternator.
The stuff I have came on an '98 Explorer engine I purchased that I installed in my '70 Mustang. I used a set of '87-'93 Fox-body Mustang brackets, A/C compressor, P/S pump and '94-'95 130-amp alternator on mine, so I don't need them.
I'd sell all of it to you for $200 + shipping, and they should be in pretty good shape.
Let me know . . .
dbfarr
191
Boise ID
Feb 2, 2009
  • Feb 2, 2009
$200 is a bit more than I had planned, are you willing to negotiate?
If so PM me.
Don
stonecoldtx
214
Dallas, TX
Feb 2, 2009
#10
  • Feb 2, 2009
  • #10
If so PM me.
Don
I just did a quick search on car-parts.com to find out the lowest prices for the parts; I found an A/C compress for $20 + shipping, an alternator for $20 + shipping, a P/S pump for $20 + shipping, and was unable to find any of the other components there, including the P/S pump reservoir, brackets, idlers, etc., so I looked on E-Bay.
E-Bay didn't have any brackets listed there for 5.0's, but they had a couple listed for 4.0's; the A/C bracket was listed at $25 + shipping and the P/S pump bracket was listed at $35. I think the reservoir is the same between the engines, and the lowest priced one I found was around $20 + $8 shipping.
If you put the figures all together, you have $120 for a mixture of prices for the V-6 and the V-8 as the lowest possible price I could find.
I figure I can make at least 25% more on the brackets listed there, and can probably make 10%-20% on the alternator, P/S pump and A/C compressor, so with that in mind, I'd sell you all the parts I have for $135 + shipping.
I don't know where you're located, but if there are any salvage yards around near you, you might be able to scrounge these parts up yourself for less than this amount, and I would encourage you to do that . . . you might end up with a great deal!
dbfarr
191
Boise ID
Feb 2, 2009
#11
  • Feb 2, 2009
  • #11
135 + shipping sounds pretty reasonable, I'll pm you and work on some details.
Once all is said and done, I'll get some pics for posterity's sake and post them. Hopefully that'll sastisfy for the future.
Don
