Extremely Weird Starting Issue.
5point0dude
51
Ok, I have never experienced something like this with my car before. It's a 1991 5.0 LX 5-speed with around 140k miles. A few weeks ago I began having a starting issue, turned out to be a bad battery cable. Car drives perfectly for about two weeks, then suddenly when I'm about to head out last Sunday night, I got to start the car and a terrible screeching/whining sound comes from the engine compartment. I shut the car off and take out the key and the engine is still running. Right away I think the starter is still engaged. I unhook the positive cable and the car shuts off. The cable was really hot. The next day I try push starting it and it does the same thing with the noises. I eventually take it to the shop and after a week of having it, this is what they have told me: They've tried 4 different starters and it keeps doing the same thing. One day they put a new starter in and the car starts and runs perfectly. They bring it back, let it cool down, then try it again. The starter is sticking again. They've put brand new battery cables on it along with a new starter solenoid. Nothing is working. They tell me today that they're going to call Ford and see if they know anything. I'm pretty damn stumped myself. Does anyone have a clue what it could be? Also, the battery is only about 9 months old (I don't know if that makes a difference or not), and the ignition switch was replace about a year ago. If any of you guys have any info I would appreciate it greatly. Thanks.
This has to be too simple of an answer, but did they replace the solenoid again??? Maybe mis-wire it? I had a good brand solenoid stick right out of the box.
@jrichker has a great starting system diagnostic list I would take to them at this point.
I had the same problem as you, come to find out it was my ignition switch was good but the plastic slide that contacts just below the switch was the issue. There is a connector just below the switch with a block of wires that connects to the aluminum housing of steering column. Carefully pull that off and look to see if the black plastic contactor broke the release tab. Or broken spring. When you turn the key on the pin pushes the contactor forward, as it pushes it forward it slides up and locks in so when you release the key and running it pulls the contactor back away from the start position. Mine broke,in turn sticking the contactor in the start position. Had me stumped for 3 months. 8 starters ,5 different solenoids, and one jacked up flywheel. And if I was to listen to my grandfather the first time I never would have had to deal with all this crap. He was right straight from the beginning saying "it's in the key switch area. Check that out first" I was young and knew it all.
Try starting there and see where that gets you.
No Crank checklist for 5.0 Mustangs
Revised 24-Oct-2013 to update voltage drop figures.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of slow crank, no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .25 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch or solenoid
100 mV Ground
0.0V Connections
A voltage drop lower that spec is always acceptable.
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
