F-cam Vacuum
  • Thread starter Thread starter yellowclone
  • Start date Start date May 25, 2006
Y
yellowclone
68
  • May 25, 2006
How much vacuum should I have at idle with a F-cam? I am showing 17 and I think that is high. I was thinking a stock cam showed 17 . Does this mean I have a vacuum leak some where?
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
May 25, 2006
  • May 25, 2006
if you had a vacuum leak it would be lower. if its 17 thats good. id just let it be
Y
yellowclone
68
  • May 25, 2006
Thanks. I was just wondering because I saw a video of a car with a F-cam and the gauges was only showing like 10 or 11lbs of vacuum. So your saying that with a vacuum leak, it would read lower because I thought it would the opposite.
vristang
4,933
101
124
Seattle
May 25, 2006
  • May 25, 2006
A vac leak will decrease the resistance for air entering the intake, so the vac signal will decrease.
Vac signal will vary from car to car.
You are good with 17"
jason
Modular2v
3,222
23
99
oklahoma
May 25, 2006
  • May 25, 2006
not to hijack the thread but does anyone beside me having braking problems with bigger cams? i have a trick flow stage 3 and if i get on the brakes really hard it kills the car, i guess the cam is not drawing enough vacumm?
vristang
4,933
101
124
Seattle
May 25, 2006
  • May 25, 2006
Vac cans can help with this.
Several companies produce them.
Try Comp Cams first to get an idea of what they look like.
I am pretty sure they offer one.
jason
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Edelbrock 1406 install help
  • scottcarp10
  • Dec 11, 2025
Fox 5.0 Mustang Tech Dec 15, 2025
scottcarp10
