  • 1994 - 1995 Specific Tech
factory hood shut with tall decks and intake spacer?
  • Thread starter Thread starter fiveoho
  • Start date Start date Feb 6, 2007
1 of 2 Next Last
fiveoho
1,958
TN
Feb 6, 2007
  • Feb 6, 2007
first question:
i hear running 1.7's with factory valve covers is a hit or miss as far as clearance. correct?
next questions:
if i run tall deck valve covers to clear 1.7's, i will then have to run a intake spacer to clear the valve covers. after i do that, will the factory hood close?
im guessing the strut tower brace is just totally out of the question? lol
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Feb 6, 2007
  • Feb 6, 2007
3/4" spacer on my cobra intake and stock hood closes fine
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 6, 2007
  • Feb 6, 2007
I have a 3/8" trickflow spacer and it rubs on the blanket on the hood, but still shuts.
Scott
go-stang5.0
2,244
Glenview,Il
Feb 6, 2007
  • Feb 6, 2007
I have a performer rpm II and the intake touches the hood with no spacers or anything.
trav_19
810
Jackson, MI
Feb 6, 2007
  • Feb 6, 2007
well i know they recomend a 3/8 spacer to clear the valve covers with a hci kit to get the egr away but thats on stock valve covers....3/8 does as mentioned rub the carpet under the hood....so it may be close you might need a taller spacer?? do you have a egr?
F
fiveohh94gt
277
  • Feb 6, 2007
fox valve covers with the oil baffel removed will clear MOST 1.7 rockers and will fit without an intake spacer on a cobra intake. I'm currently running the 1/2in spacer and the front bolt on the intake barely touches the hood blanket on the cobra intake
fiveoho
1,958
TN
Feb 7, 2007
  • Feb 7, 2007
guys i appreciate all the input.
if i have to run tall decks, is it likly i can get away with a 3/8 spacer? surely wont have to go to a 1" spacer will i?
(will be using a TFS street intake upper and lower and motorsport covers)
i just hate to spend money on a hood
gcomfx.com
3,690
Republic, MO
Feb 7, 2007
  • Feb 7, 2007
I'm waiting on my engine to be finished. Kinda in the same boat only I have a 96 Cobra hood. I've got another 2 weeks before I get the engine, but I most likely won't put the hood back on until it's running right. Mine will be the TrickFlow Track Heat and 3/8 spacer over the TrickFlow covers.
Be sure to post an update if you find out. I'll try to do the same.
fiveoho
1,958
TN
Feb 7, 2007
  • Feb 7, 2007
i appreciate that. you will know before i will more than likely.
btw, is those trickflow covers tall?
gcomfx.com
3,690
Republic, MO
Feb 7, 2007
#10
  • Feb 7, 2007
  • #10
Taller than stock yes. I bought the Trick Flow top end kit. I'm ashamed to admit it, I've had the kit for a month, and haven't seen any of the parts yet. I had them shipped straight to the engine builder which is a a couple hours away.
trav_19
810
Jackson, MI
Feb 7, 2007
#11
  • Feb 7, 2007
  • #11
well a 3/8 spacer is all the bigger that you can go as that already hits the carpet on the underside of the hood....w/ the 3/8 the egr will clear stock valves if your running the egr still you might have more of a issue with tall valve covers....?
95opal
5 Year Member
Nov 16, 2004
449
20
39
Feb 7, 2007
#12
  • Feb 7, 2007
  • #12
My stock hood, 3/8 and TFS street used to rub the blanket. But the hood still closed with no problem.
fiveoho
1,958
TN
Feb 7, 2007
#13
  • Feb 7, 2007
  • #13
thanks man
fiveoho
1,958
TN
Feb 7, 2007
#14
  • Feb 7, 2007
  • #14
with stock valve covers?
fiveoho
1,958
TN
Feb 7, 2007
#15
  • Feb 7, 2007
  • #15
so even if i run stock valve covers and a tfs intake, i will STILL have to run a spacer?
95opal
5 Year Member
Nov 16, 2004
449
20
39
Feb 7, 2007
#16
  • Feb 7, 2007
  • #16
The reason I ran the spacer was for clearence w/ the egr and if im not mistaken my injectors needed clearence also. Dont quote me on that as its been a while since i swaped the intake.
trav_19
810
Jackson, MI
Feb 7, 2007
#17
  • Feb 7, 2007
  • #17
yes when running a tf intake the 3/8 spacer is needed to clear the egr from the valve cover.
fiveoho
1,958
TN
Feb 7, 2007
#18
  • Feb 7, 2007
  • #18
wonder if a 3/8 could be used to clear the egr AND tall decks?.........prob not?
-thanks for yout help btw
trav_19
810
Jackson, MI
Feb 7, 2007
#19
  • Feb 7, 2007
  • #19
how much taller is a tall vc compaired to a stock vc??
fiveoho
1,958
TN
Feb 7, 2007
#20
  • Feb 7, 2007
  • #20
ditto
1 of 2 Next Last
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
J
  • Locked
SOLD 93 cobra intake manifold
  • Jimmer009
  • Jan 19, 2025
  • Engine and Power Adder
Engine and Power Adder Jan 22, 2025
Jimmer009
J
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
