  • 1994 - 1995 Specific Tech
FAN ISSUE
  • Thread starter Thread starter xc_myers_06
  • Start date Start date Mar 19, 2006
xc_myers_06
64
Nebraska
Mar 19, 2006
  • Mar 19, 2006
Here's the Situation i turn the car in the on position, axuillary, turn it on the front fan turns on and runs constantly and doesn't shut off. how can i fix this? to make it turn on at a certain temp instead of constantly?
HISSIN50
34
129
Mar 19, 2006
  • Mar 19, 2006
I would look to make sure someone didnt rewire it to do so. Look at the CCRM at Pin 14 and Pin 17. Note if there are any wires splices to those wires.
You can also use your meter to check for 12 volts at pin 14 and ground at pin 17. Either would indicate that someone rewired the fan (this latter method allows for you to detect if someone spliced into the wiring elsewhere than at the CCRM).
Good luck.
badstang123
397
Santa Clarita, CA
Mar 19, 2006
  • Mar 19, 2006
It's a little funny that you want yours to stop doing that and I spent some time wiring mine to do so
Pokageek
2,767
MA, USA
Mar 19, 2006
  • Mar 19, 2006
I have a CCRM willing to get rid of for %50 if you want it. It works fine and I don't need it.
xc_myers_06
64
Nebraska
Mar 19, 2006
  • Mar 19, 2006
is it ok? for that fan constantly? what are the pros/cons of it doing that? it didn't used to until i put on a new starter in my car.
HISSIN50
34
129
Mar 19, 2006
  • Mar 19, 2006
The life of the fan motor will be reduced. Having the fan spin when the car is not up to temps is kinda useless (for the fan and charging system).
I would go over the wiring harnesses that you touched during the starter install (I am having a time trying to figure out what you could have touched, but if someone did rewiring for the fan, who knows). All one can do is check the Pin values at the CCRM and check things that you were near during the other install.
Good luck.
xc_myers_06
64
Nebraska
Mar 19, 2006
  • Mar 19, 2006
i don't ever remember the fan being on constantly though, i always thought the fan ran only when it reached the certain temp. but i dunno what i could of hit to make it do that. thats weird. i just don't wanna be replacing more stuff on the car. i would rather do mods instead
HISSIN50
34
129
Mar 20, 2006
  • Mar 20, 2006
You really should not have to replace stuff on the car. The issue started apparently from something being bumped or moved, so it should be reversable. It could be as simple as someone having wired up a high-speed fan-switch and having disconnected the wiring down the line. If they cut the wire away from the CCRM (which is easier for someone to do. Seems logical) and that wire became grounded, it would turn the fan on.
You just need to spend about 1 minute with your meter seeing what is going on at the CCRM. It might be a 2 minute fix for you.
Good luck.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Z
Cool fan issues
  • Zipcity
  • Dec 23, 2025
1994 - 1995 Specific Tech Dec 27, 2025
manicmechanic007
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
