  • 1994 - 1995 Specific Tech
fan swich mod
  • Thread starter Thread starter 96darkhorse
  • Start date Start date Aug 15, 2004
9
96darkhorse
693
wilmington, california
Aug 15, 2004
  • Aug 15, 2004
can anybody tell me or show me everything that i will need to do this?
my friend did it on his 03 Z28, looks pretty easy. i remember someone posting a diagram of some sort. thanks
squall9393
534
Oceanside, CA
Aug 15, 2004
  • Aug 15, 2004
Check the "94-95 GT/Cobra Specific FAQ Sheet Thread" at the top of the thread listings in this forum. It's in there.
GTJake
3,049
Ann Arbor, MI
Aug 15, 2004
  • Aug 15, 2004
http://www.allfordmustangs.com/Detailed/499.shtml
Jake
squall9393
534
Oceanside, CA
Aug 15, 2004
  • Aug 15, 2004
Oops sorry man- I read your thread wrong. Thought you were looking for the high speed fan mod.
9
95stangGT
513
Buffalo, NY
Oct 19, 2004
  • Oct 19, 2004
Isn't that the same thing as what the link shows to do?
chefster
426
michigan
Oct 19, 2004
  • Oct 19, 2004
ya i did mine ..get a powerful toggle switchwith right amount of amp capacity..they like to get hot because of resistance...50 or 60 amp....then i mounted it in my cig lighter hole in front of my stick shift...remove the entire plastic mold to get behid it..it pops right out by squeezing the sides. I ran a wire from the power side out of the 60 amp fuse in the box under the hood,thru a boot on the fire wall under the dash and to the switch....out of the switch a snaked a return power line to the power feed to the fan...there are three wires that feed into it..unplug the plug at the fan and splice into the right wire i don't remember which one you'll have to put power to the different prongs on the fan to see which one works...be sure to get good connections at the switch and at the fan..it draws alot of power and resistance can surre heat things up
9
95stangGT
513
Buffalo, NY
Oct 19, 2004
  • Oct 19, 2004
What gauge wire should be used?
Also, why is the one listed in our FAQ archive so different than in the link listed above? That one doesn't need to be connected to the power distribution box or nothing.
squall9393
534
Oceanside, CA
Oct 19, 2004
  • Oct 19, 2004
Indeed it does. Sorry I'm not too familiar with seeing the mod at a glance. I just got an aftermarket fan for mine and it saves on load power and runs high all the time.
94TURBO5 O
2,509
VA
Oct 19, 2004
  • Oct 19, 2004
Tap the ccrm pin #17 with a wire. Run that wire to a toggle switch. Run another wire to a ground and connect it to the toggle switch and you're all set.
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Thinking of selling my stang.
  • 2003 mustang gt modded
  • Mar 26, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 26, 2026
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
