  • 1994 - 1995 Specific Tech
feel retarded asking this
  • Thread starter Thread starter 91LX_5L
  • Start date Start date Oct 24, 2004
91LX_5L
1,943
British Columbia
Oct 24, 2004
  • Oct 24, 2004
where is the PCV valve located? Iv never replaced it before, whats it do and should I replace it?
I know quite a bit about cars but for some reason I allways overlooked this?
stangla2
90
  • Oct 24, 2004
behind the upper manifold and its a t-coupler.connected to it on the lower manifold
91LX_5L
1,943
British Columbia
Oct 24, 2004
  • Oct 24, 2004
should I replace it, I allways see it in the oil/filter and fuel filter section, I change those but never have the PCV
SN95StangMan
1,292
Lynwood, CA
Oct 24, 2004
  • Oct 24, 2004
You should chage it if it has never been replaced. While you are there you should get a new pcv screen too. Those things can get real clogged with oil.
HISSIN50
34
129
Oct 25, 2004
  • Oct 25, 2004
i recommend a new screen, grommet and valve. some folks have had issues with the aftermarket valves not fitting tightly (read vac leak). all three from the dealer are ~20 bucks. do it and forget for 2 years.
BTW, it vents crankcase pressure.
good luck.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
