Engine Feels like miss firing......?
  • Thread starter Thread starter essgt1
  • Start date Start date Apr 8, 2013
essgt1
Florida
Apr 8, 2013
  • Apr 8, 2013
Hi all,
Here is the problem. Lately when I first start my mustang and drive it feels like it is miss firing (breaking up or as if the mufflers are clogged) for the first 5 to 10 minutes or til she gets warmed up. After she is warmed up she runs strong as if it never happened. There are no cats on the car and has a BBK h-pipe with shorty headers. Was wondering what the issue may be and if it is a simple fix. All your suggestions are muchly appreciated.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 8, 2013
  • Apr 8, 2013
Did you run the codes? How about those Cool Ranch Doritos. Mighty Tasty.
Reactions: toolow91
essgt1
Florida
Apr 9, 2013
  • Apr 9, 2013
Unfortunately no , I dont have one of those code readers. Did it again today, almost sounds as if it wants to back fire but doesnt.
88LX5.Oh
1,442
205
94
Arkansas
Apr 9, 2013
  • Apr 9, 2013
No need for a code reader. Jrichker has a post that shows how to dump the codes with just a paper clip. You can try the search function to see if you can find the thread.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 9, 2013
  • Apr 9, 2013
You don't need a code reader. All you need is a paper clip or a piece of wire and maybe a test light if your mustang doesn't have a CEL. Search the tech sticky for Jrichker's post about how to pull codes. It is very easy and should be your starting point as the computer will often tell you provide you with the codes where the issues are.
Admin Dude
Jan 4, 1985
43,590
21,751
234
Box behind Walmart
Apr 9, 2013
  • Apr 9, 2013
http://www.stangnet.com/mustang-for...…-spittin’-and-sputtern’.867484/#post-8719503
MFE92
1,094
373
124
Phoenix
Apr 9, 2013
  • Apr 9, 2013
Sounds like you have a collapsing lifter or a compression problem on startup. Here's what I'd do: Turn the ignition on. Floor the gas pedal and hold it, which invokes "clear flood" mode and actually shuts off the fuel. Crank the engine for a few seconds and listen to it. Does it go r-r-r-r-r-r-r-r all nice and even, or does it go R-r-r-r-R-r-r-r getting louder as the crank passes a weak cylinder? Poor man's quicky compression test. It won't tell you which cylinder is weak unless you pull the distributor cap and watch where the rotor is pointing as it passes the weak cylinder, but it'll definitely tell you if you have a weak cylinder. And a weak cylinder is only caused by valves not actuating properly or the cylinder not sealing properly.
So, if it clears that quick and easy test, you can rule out compression and move on to spark and fuel.
Reactions: 88LX5.Oh
essgt1
Florida
Apr 13, 2013
  • Apr 13, 2013
Thanks , will try ou and let you know what i find
essgt1
Florida
Apr 13, 2013
  • Apr 13, 2013
Ok MFE92, I tried what you said and it definately sounds like R-r-r-r-R-r-r-R. If a cylinder doesnt seal properly would you burn more oil or a least smoke coming out of the tail pipe on the side in question? My oil levels are fine and still has that honey color to it. How bad can this issue be?
MFE92
1,094
373
124
Phoenix
Apr 13, 2013
#10
  • Apr 13, 2013
  • #10
Depends on what the problem really is. Time to run a real compression test on it.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
J
Lost low end torque
  • JJ's90fox
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2025
Methodical
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
