finally have some results!
  • Thread starter Thread starter inphiniti
  • Start date Start date Sep 27, 2009
I
inphiniti
412
Providence, RI
Sep 27, 2009
  • Sep 27, 2009
well after months of bull**** and setbacks, the car is finally back together and running mighty fine might i add... car has a new aode w/ a shift kit and alto reds as well as a Edge 2400 stall. on the dyno the car made 256.94 for hp and 278.96 for tq. i guess u really do lose alot through the auto trans...
i was trying to get my dyno sheet scanned in but evidently my scanner doesnt want to work, so ill have to hold off on that. this was on a dynojet btw
Pokageek
2,767
MA, USA
Sep 27, 2009
  • Sep 27, 2009
Sounds like an awesome set up. Very respectable street car and fun ride I'm sure. You'd prolly be 285 thru stick. Track heat would give you more with little sacrifice of low end. But.. there's always the "more" bug...dont get too caught up in that.
I
inphiniti
412
Providence, RI
Sep 27, 2009
  • Sep 27, 2009
yeah bro, i never realized how much u lose through an auto... plus running 18s im sure didnt help either... the car sounds INSANE w/ the borla stingers, but im definitely needing some tail pipes put back on... inside the cabin the sound and smell is a little rediculous now... but all in due time...
who knows whats n ext
94-302-vert
1,947
NE CT
Sep 30, 2009
  • Sep 30, 2009
Jimmy, was it worth all of the hassles to get here?
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 30, 2009
  • Sep 30, 2009
Yes indeed, roughly 23% and that'll vary depending on how much torque converter slippage there is. A higher rpm stall converter can sometimes cause a slight loss on the dyno but that doesn't matter. What does matter is how well the car performs at the track.
I
inphiniti
412
Providence, RI
Sep 30, 2009
  • Sep 30, 2009
eh, yes and no. the car is insane, but im still getting used to it for DD use. the dumps definitely got to go, i see tailpipes in my near future!
Shocked by Dyno Results - 1990 Mark VII with 5.0 HO
  • 88Mark7
  • Mar 12, 2018
  • Other Auto Tech
7K
Other Auto Tech Oct 6, 2018
I Bleed Ford Blue
Fox Something Weird Happened Today...related To My Dynotune?
  • killer5.0
  • Oct 19, 2017
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2017
killer5.0
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
Finally got some dyno numbers wanted some input.
  • 69Rcode_Mach1
  • Mar 1, 2010
Classic Mustang Specific Tech Mar 5, 2010
brianj5600
CEL flashing, bad idle, severe misfire, P0302 P0316, compression test results
  • evolucion311
  • Aug 18, 2011
  • SN95 4.6L Mustang Tech
  • 9 10 11
50K
SN95 4.6L Mustang Tech Dec 29, 2011
1987stangman
