First Maintenance After Purchace
  • Thread starter Thread starter mannymendez25
  • Start date Start date Feb 12, 2015
M
mannymendez25
35
Feb 12, 2015
  • Feb 12, 2015
I just purchased my first Mustang!!! It's a beautiful 1992 LX 5.0 Convertible with 41k miles. I plan on doing my first maintenance such as oil, oil filter, air filter and spark plugs. What else? Fuel filter?
Also, what oil viscosity? Do I use the Ford recommendations or go a little thicker?
Any additional information would be greatly appreciated.
Thanks,
Manny
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 12, 2015
  • Feb 12, 2015
I would go ahead and change the cap, rotor, and plug wires, also don't bother buying any new fangled type of sparkplug as the plain old copper ones work best in the 5.0. You could check the timing and replace the belt along with the things you listed.
Reactions: 90lxwhite
M
mannymendez25
35
Feb 12, 2015
  • Feb 12, 2015
should i stick with motorcraft parts?
stanger2003
  • Feb 12, 2015
I would stick to all ford products such as motorcraft for the tune up....
oil change
oil filter
Fuel Filter
New spark plugs,
New coils or wires (if you have the money)
transmission fluid (if automatic)
Air Filter( I would change to cold air intake if haven't done so yet)
M
mannymendez25
35
Feb 12, 2015
  • Feb 12, 2015
Sounds good.
where is the Fuel Filter?
I plan on getting a K&N air filter for the factory housing. the car is completely stock and i want to keep it that way, other than the flowmasters i installed yesterday!!!!!
What viscosity oil should i use?
Where can i buy motorcraft parts online? i assume it will be cheaper online than at my local dealer.
stanger2003
  • Feb 12, 2015
what state do you live in? viscosity depends on weather.
You can get all of these parts online at autozone.
The fuel filter is located in back of the car right behind the gas tank. you might have to lift up the car to change this.
M
mannymendez25
35
Feb 12, 2015
  • Feb 12, 2015
I live in Florida.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 12, 2015
  • Feb 12, 2015
When you change the Fuel Filter stick a couple vacuum plugs on the old filter when removing it as you will take much less of a fuel bath.
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Feb 12, 2015
  • Feb 12, 2015
Motorcraft parts are over priced and are made in Mexico and China. Google it. Get a BWD cap and rotor. If you have the money get a good thick set of plug wires such as Taylors. Oil, you'll be fine w 10w30 and change regularly. The only difference you'll notice between "regular" and synthetic is the price.
Boosted92LX
5,721
4,244
224
Feb 13, 2015
#10
  • Feb 13, 2015
  • #10
A lot of seasoned fox guys say don't waste money on a cold air kit, just remove the silencer and replace the panel filter with a k&n. The factory setup actually pulls cold air from the fender, as most "cold air kits" don't and you see no difference in performance. I have only used one aftermarket cai and it was more hassle to me than it was worth.
Reactions: 90lxwhite and A5literMan
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 13, 2015
#11
  • Feb 13, 2015
  • #11
I ran 14.2's with a bone stock brand new 93 GT with just a k&n panel filter,2.73 gears,stock Michelin tires,air silencer removed. I then added a underhood cone filter/intake and actually slowed down. Also had a wandering idle because of that open element. If staying "stock" just add the k&n.
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
new edge coolant leak need advice asap
  • 2vBoogs
  • Nov 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 19, 2026
Mustang5L5
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Upgrade Advice on an 89 GT Convertible NJ
  • SteakDad
  • Apr 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 18, 2025
limp
